open dialogbox with ruby issue/bug!?
Postby Nubeat7 » Mon Nov 25, 2013 3:06 pm
while trying to do save/load via ruby i recognised that there is an issue with calling a window via win32api.
the issue is that rubymodule shuts down because of excessive processing when no interaction with the opened windows are happening..
here is a schematic which shows the described issue, it includes a filedialog and just a simple messagebox
save_load_ruby_issue.fsm
(2.05 KiB) Downloaded 238 times
Re: open dialogbox with ruby issue/bug!?
Postby Nubeat7 » Mon Nov 25, 2013 3:29 pm
further testing has shown that after exporting the schematic to exe or vst nothing is happening when trying to save /load or open the message box
Postby CoreStylerz » Mon Nov 25, 2013 5:58 pm
Strange :!:
Need websites or custom plugin web services?
PM me if you are interested.
CoreStylerz
Postby MyCo » Mon Nov 25, 2013 7:48 pm
It's normal behaviour. The message box blocks the ruby thread from doing its work. So FS thinks this blocking is caused by a bad ruby code, and deactivates that.
For exporting: You have to publish the ruby folder from the FS-Program directory with your executable.
MyCo
Postby Nubeat7 » Mon Nov 25, 2013 9:30 pm
MyCo wrote:It's normal behaviour. The message box blocks the ruby thread from doing its work. So FS thinks this blocking is caused by a bad ruby code, and deactivates that.
oh, thanks for the tip of publishing the ruby folder, now it opens the windows in the exe file but ruby still gets turned off, not only in FS!
the example with the message box is taken from the userguide (i know there is a methode for message box without win32api call) but shouldnt this be working after exporting?
or is there a way to make it work?
it would be also interesting how to use the IFileDialog...
Postby MyCo » Mon Nov 25, 2013 9:36 pm
I don't know of any way to make this work with Ruby. You have to open the windows in another thread, that's the only way to make it work.
MyCo
Postby Nubeat7 » Mon Nov 25, 2013 10:38 pm
:( too bad, thanks!
Postby francoisreme » Sat Mar 18, 2017 12:07 pm
Yo can create a new ruby thread, this way it will not block ruby
francoisreme
cron
