How do you connect LFO to DIst amount and phaser freq more
How to connect LFO to.
Phaser Freq
Distortion Amount
LFO rate
LFO gain
Can some one show me pls. mybe an example or something. Like an example schematic or some images pls.
Phaser Freq
Distortion Amount
LFO rate
LFO gain
- djbrynte
Re: How do you connect LFO to DIst amount and phaser freq mo
if your lfo is polyphonic use a poly to mono to send it to the blue effects
- adamszabo
but are the phaser freq the amount on phaser or where is it?
- djbrynte
here is how i mean check the fs examle
- streams where.fsm
- (51.6 KiB) Downloaded 869 times
- djbrynte
i just showed an example. its no signal or nothing i know.
Im just confused i dont know where i should put the streams.
What i mean is. Where in the LFO is Gain and Rate signal. Where shall i put the x stream.
I mean, How should I connect the signal from matrix to those choices. I do not know where to put the stream so it gets connected correctly.
LFO gain
LFO rate
Phaser Freq
Distortion Amount
Its supposed to come signal from matrix. what source u now connect.
But i dont know where i hook up the stream. On what signal (Line) Blue green grey. Where do i put the stream the x one so its right for LFO gain and LFO rate and then where inside the phaser to get freq on phaser and then amount on distortion.
i mean like is that the right place to put the x stream for modulate the LFO gain and LFO rate. i know there is no signal now. thats mybe make you understand
i hope you fols get it
LFO gain
LFO rate
Phaser Freq
Distortion Amount
- djbrynte
I think you are asking way too many things at once. From your question I see you want help with setting up a matrix, understanding how white and blue streams interact, and how to add frequency and distortion amount to your effects. I think you should take things one step at a time. Does your phaser have a frequency knob? Thats there you should set up the lfo. Does your distortion have a dist amount or only a dry/wet? Then you should first write a new distortion with an amount control and put your lfo there.
- adamszabo
I got it solved i did it right some how. a mate told me some of the connections where 0+1 to 0+2. Other then that all seem to be correct
- djbrynte
Its still not working i show.
- Untitled-2 copy.png (69.93 KiB) Viewed 20861 times
- Untitled-1 copy.png (68.83 KiB) Viewed 20861 times
- djbrynte
