Testing applications w/out using exe. files?
I am new to flowstone. I spoke w/ a gentleman at Lynxmotion Inc., he was very informative. He claimed, inorder to test my application, I did not have to make an exe. file. and exe. file was so if i planned to use the program on another pc. If this is true, may I have some simple instructions as how to do this? Maybe w/ an image loader, a switch for on/ off. etc? Thank You...
- Lord Ra
Re: Testing applications w/out using exe. files?
This is correct!
With FlowStone there is no compiling necessary to run and test your program. In fact the FlowStone program is running all the time so there are no instructions as it is already running.
If you want to make a program that is stand alone then indeed you then need to make an EXE, but up to this point your can test your application in the development environment.
- DSP
