Save as -> Improper Argument (Bug?)
Posted: Sat Mar 09, 2019 1:57 am
I've just been setting up FlowStone on my new(ish) laptop, and I've discovered a strange problem. I thought I'd ask here first before filing a bug report in case it's something that's known (I found one mention when I searched, but it was a stub.)
If I try to save a file with a new name by selecting "Save As...", I simply get an error popup telling me; "Encountered an Improper Argument". If I dismiss the popup, I can carry on as usual without there seeming to be any ill effects, and the contents of the schematic don't seem to make any difference. "Save" works fine to save the file with the same name, and all file loading dialogues work as they should. Turning off auto-recovery makes no difference, nor does the file location of the current schematic.
I'm using FS v3.8.0.1 Skylark, which is what I'd been using before with no problem (Windows XP on an ancient Quadcore PC), and I'm installing on a Windows 10 machine (Off the shelf Intel i5 laptop. Dual boot with Ubuntu Linux.) Running FS in Windows' legacy compatibility modes makes no difference.
Stupidly, I hadn't tried any of this before copying over my old toolbox and tinkering with a few old projects. Deleting my toolbox modules, or reinstalling FS haven't made any difference, though. The only thing left to try is an install following a registry clean out etc., which I'll have a go at when I next get the chance (I need a bit of a break from it right now, otherwise my landlady will start to wonder who I'm arguing with! )
Even if I get it sorted, it would be useful to know if there's something which causes this which I should avoid doing, or if it's a sign of other problems that I haven't noticed yet. It's not the end of the world, as the way that I manage files doesn't require it very much, and it can be worked around if I really need to. I'll keep you updated about anything I manage to sort out myself.
