Flowstone Portable
Flowstone Portable
Hello Gang,
Quick question, can Flowstone be made to run from a flash drive (portable) without any problems?
Later then, BobF.....
- BobF
Re: Flowstone Portable
That's the only way I've ever done it, because I never use my Windows machine for downloading things from the Web; only a Mac. So I download on the Mac, copy to a thumbdrive, then install on the PC from that.
@K Brown,
Sorry, my bad, I meant run from a flash drive.
Thanks though.....
Cheers, BobF.....
Thanks though.....
Cheers, BobF.....
- BobF
Unfortunately, Flowstone uses the registry and #appdata#. So you can copy the Flowstone folder to an external drive, but it will only run on a PC, where it was installed before.
Thumb Drive / Flash Drive same thing isn't it?
Oh, I see, you said run from a flashdrive, not installed from one.
Users browsing this forum: No registered users and 52 guests
