DAW Automation envelopes - Jagged output.
• Page 2 of 2 • 1, 2
Re: DAW Automation envelopes - Jagged output.
If it turns out to be an issue in other DAWs then it may be worth looking at for a future fix. If not then you could ask Cockos support maybe.
I wouldn’t know how to make a local undo for an array. Of course FS can do this but how you would get a VST to do it I don’t know. Maybe you could have an edit feature with a commit option, wherein the edit “buffer” then passes the data to the system for storing. I think the DX7 could do this, so you play around with the sound then store into a voice. Nothing gets overwritten until you commit…?
My Quilcom NINE could selectively copy from voice 1 to the other 8 voices to avoid repetition of settings. You could see if that might be useful. But I bet that’s not what you mean.
viewtopic.php?f=3&t=4419&p=24991&hilit=quilcom+NINE#p24991
You have interesting questions and ideas!
Spogg - Posts: 2795
Slight shame as a made a button to push to write Envelope/Seq/lfo to track as envelope in Reaper.
lalalandsynth - Posts: 600
The Nine , is great , very clean work ! It does sound slightly like Razor like I saw someone mention but it also reminds me of the Korg Prophecy. It has this slight woodwind vibe to it that the Prophecy has.
I might be able to make some sort of copy paste with this , maybe instead of send to all , a send to 1 or 2-3-4 ?
But that would require a dropdown (or something) for each 1-2-3-4 button ...but its possible to come up with something from this , thanks for sharing.
Thinking out loud..would it not be possible to copy the array list from 1 ...hold it until I push button 2 , thereby pasting it into 2 ? SO , just a copy button that assumes it will copy into the next button you push ?
So instead of making a copy ..(i.e - selecting switch one , pushing a copy button , switching to switch 2 and hit paste)
It would just always hold a copy of the switch I have engaged and then by only having a paste button , you hit paste and it will paste into the next selected button?
Maybe I am overthinking it , seems like this should be doable.
I must be able to read the array into ruby and only send onwards -one time - if it gets trigger(copy) and then an int from one of the 4 switches. I am trying to hack my way through ruby to do this but seems like it should be easy with a bit of ruby skills . So far I can read the array and send via Ruby but I am having problems telling it when to send it through.
@lalalandsynt Have you been able to do it?
I find myself almost in a similar goal,
I try to call a list of automatable parameters of the schema within the same FS, and still can't find the way,
Now I think I have to find some primitive to open the preset txt and based on that data, filter the parameters that I want to activate or deactivate in the Vsti, or simply see them to find them more quickly,
I will elaborate it and if it works for me, I will attach it.
ErvSoft - Posts: 30
I did it, it was easy, I just added a primitive text load that extracts the content of a txt, of the file dialog menu,
which can be in any other assigned extension and voila,
then in this preset manager that I modified, you put it in your scheme and when saving or loading the preset,
the list of parameters will be written to the green table stings.
ErvSoft - Posts: 30
Users browsing this forum: Majestic-12 [Bot] and 23 guests
