Re: save multiline text in preset
Posted: Tue Sep 12, 2017 12:35 pm
adamszabo wrote:The easiest and most simplest solution is to convert your multiline string to hexadecimal then convert it back. The problem is that the string preset only holds 255 (i think) characters and you can only write a small description, but it does the job
That's a cool idea! Also, it stays within the VST definitions. And yes, as I said earlier in another post, there still is the 255 char limit. You have to take care of it, or else the text will be cut.
