Free C Simple Arp Sequencer
Postby wlangfor@uoguelph.ca » Tue Sep 15, 2020 8:29 pm
Here's a C+ alternative to the Ruby Simple Arp by Exo, which was ported to Ruby and has become the staple of sequencers in flowstone. It's less a modification than it is a gui that matches a more modern approach. While the previous interface offered more control it was also clunky and meant im-precision.
It uses the Step LFO design from the Synthmaker days. I've noticed that Reason has problems accepting too much midi data from sequencers in general.
Perhaps a resolution might be to use ruby as a "middleman", so as to then re-process the midi through ruby; making the calls the stuff of "pure data". Perhaps that is a fix and perhaps not; I do not have reason and it is just a guess becasue I have witnessed the Ruby version working fine in Reason (if used only once and not many times for different samples).
Youtube Video Download available here:
Youtube Video (older video):
Youtube Video How to Add a Ruby Redraw (no more redraw primitive!) to it:
More info:
https://dspplug.com/downloads/flowstone-free-c-simple-arp-alternative/
I was able to complete the x32 version "to a degree" (now only 32 bit included in the .zip). It sounds much better.
Last edited by wlangfor@uoguelph.ca on Fri Sep 18, 2020 8:26 pm, edited 1 time in total.
My youtube channel: DSPplug
Re: Free C Simple Arp Alternative
Postby wlangfor@uoguelph.ca » Wed Sep 16, 2020 3:28 pm
Updated to 32 bit, improved the sound - pressed for time and it will be updated later today.
Postby MichaelBenjamin » Wed Sep 16, 2020 7:24 pm
Last edited by MichaelBenjamin on Mon Sep 21, 2020 11:02 am, edited 1 time in total.
MichaelBenjamin
Postby adamszabo » Thu Sep 17, 2020 7:42 am
Thank you for your efforts however this is not an "arp". An Arpeggiator retriggers the voices, this just creates pitch variations for the oscillators.
adamszabo
Postby wlangfor@uoguelph.ca » Fri Sep 18, 2020 3:29 pm
I'll be adding Ruby to the end signal so as to maybe avoid issues in reason.
cron
