Random graphic Lines
• Page 2 of 2 • 1, 2
Re: Random graphic Lines
Whenever you draw something to a view, you're actually drawing into a bitmap. Once some drawing is finished, the bitmap is shown in the view, further updated by more drawing, etc. It stays in its last state, until something else covers it. At that point the view is instructed, which part to redraw ("clipping") and it clears everything from that part of the bitmap. When you don't draw again after that, it just stays clear (clear = transparent).
This all has nothing to do with Ruby (nor green). It's just how drawing is handled in Windows.
...32bit finally
I pushed it to different direction, theres 12 fully controlled rectangles but during the time I experimented too much for freaky effects. Its a fast mash-up. I will work on it further anyway to get something similar of what it was at the beginning.
hardwarehost - Posts: 37
You see its 5 times in schematic I wrote its a fast mash up
Thanks Tulamide.
From what i see in host it only draw when we ask or when something hide the view or a part.
Strangly when the vst window is moved there's no redraw.
I suppose it redraw the view at refresh but only redraw the bitmap when call.
Interesting Art HarwareHost, i think that the creator of random make it more close that what could more represent something close to his mind.
Maybe there's some module that could reduce tick in this schematic.
I make a random color change that's more simpler. This one could change speed but not
so much.
Also i use a method to produce ticker at different speed in one place then send wirelessly all the ticks.
So a module that need slow tick will not add his own counter to the list.
I also go wireless to send the size or area of the view.
I will someday try a method to add smooth transparency border with png.
For now i experiment with bitmap feedback or smoothing..
Using the create bitmap with less pixels will add some strange blur.
so much.
- GraphicBitmapFeedback.fsm
- (32 KiB) Downloaded 814 times
- Tepeix
Finally here's a way to make transparent traces.
But we end up redrawing all the view and not only part for a perfect result.
Maybe it's possible to redraw only part, drawing first the bitmap recorded background,
then the trace we want to add.
- transparentTraceRedraw.fsm
- (74.22 KiB) Downloaded 833 times
- Tepeix
added xy "drawing" pad
Just curious, how would I drop one of these custom modules into an existing flowstone vst project?
TIA!
TIA!
- Soundshaperzkitz
Users browsing this forum: No registered users and 69 guests
