SyncScope
SyncScope
Postby martinvicanek » Tue Sep 10, 2019 5:58 pm
Hi folks,
I had the idea of an oscilloscope synchronized to the input so that the display would be essentially static. In the analog world this was based on zero crossing. We can do better in the digital world using correlation. This SyncScope2 will grab a larger chunk of data and display a section with highest similarity (= correlation) with the last displayed data. The result is a quiet display, and you don't have to adjust trigger thresholds etc. as in the old days. If you have a synth with an animated wave display, you might want to check this out.
Have fun!
SyncScope2.fsm
(21.69 KiB) Downloaded 396 times
Re: SyncScope
Postby wlangfor@uoguelph.ca » Tue Sep 10, 2019 7:57 pm
martinvicanek wrote:Hi folks,
Have fun!
Neat, thanks MV. BTW I'll get your reverb design done within at least 3, 4 days
My youtube channel: DSPplug
Re: SyncScope
Postby Spogg » Wed Sep 11, 2019 8:25 am
This is excellent Martin and immediately went into my toolbox. :D
The more tools we have for analysis and display the better. I make very frequent use of your Slow Scope for example and it’s been able to show stuff that I wouldn’t have been able to work out without it.
Thank you for this and all the other amazing stuff you’ve shared with us.
Re: SyncScope
Postby adamszabo » Wed Sep 11, 2019 8:41 am
Great work Martin!
adamszabo
Re: SyncScope
Postby trogluddite » Wed Sep 11, 2019 5:21 pm
Thankyou, Martin. As I mostly make effects for my bass, rather than synths, the problem of stable triggering for dynamically changing waveforms with multiple zero crossings is one that comes up rather a lot for me. Problem solved! There's something rather hypnotic about watching a bass pluck slowly morph shape, now that they're not jumping around all over the place!
Re: SyncScope
Postby martinvicanek » Thu Sep 12, 2019 9:30 pm
Thank you all. Glad you find it useful.
Re: SyncScope
Postby lalalandsynth » Sun Sep 15, 2019 7:23 pm
This is quite amazing ! Thanks martin.
lalalandsynth
Re: SyncScope
Postby Halon » Thu Sep 19, 2019 2:21 am
Thank you Martin :D
Halon
Users browsing this forum: Google [Bot] and 17 guests
