clear audio at presetchange
Posted: Mon Feb 05, 2018 1:05 pm
hallo, after this was asked in the general section here is an example of how i avoid clicks, hanging notes or other audiotroubles while presetchange, specially in complex schematics where presetchanges could need up to 1 sec or more.
how it works:
when a programchange happens a trigger gets sent to the clear audio module right before the audio output and the new preset nr is holded on a sample and hold, in the output module the volume is faded to zero and clear audio is triggered which kills all audio activity, after this a trigger is sent to the presetmanagers sample and hold and the presetchange finally happens.
take care that the trigger from the output module is connected correctly with the presetmanager! if you do this wireless everything needs to be on the right level!
how it works:
