The Quilcom Wavemaker 4: Make waves!
Greetings from Spogg!
The Quilcom Wavemaker 4 is (I hope) a much improved re-work of version 3.
Its purpose is for waveform geeks to make and process single cycle waveforms for use in oscillators and cross-fading (morphing) synths and wavetable systems.
I’ve attempted to better streamline the GUI, with view buttons relating to the desired task. I’ve made many changes to the operation of the various functional parts, especially the waveform extractor on the wave draw page and the waveform routing options within the tool.
I must give special thanks to Martin Vicanek for his Wave array processors, providing a much improved smoothing function on the wave drawing page.
There’s a video you can watch to get an overview:
https://youtu.be/8E2MHDkQe9A
Download:
https://www.dropbox.com/s/i6oyg6a7xqzq4 ... 4.zip?dl=0
The download zip includes the FSM, VST plugin, stand-alone executable, user guide and a selection of short wav clips and raw text files to play with. When you unzip you will get everything inside a folder.
I hope someone finds this tool useful! All comments are welcome of course.
Download:
Spogg - Posts: 3323
Re: The Quilcom Wavemaker 4: Make waves!
Thanks Spogg
- Halon
I found an issue with the Wav save module.
For anyone interested it was a problem with the Resample prim. Since the float arrays are normalised there will be a max value for either the negative or positive excursions, or both.
In some cases, at these peaks the prim gave huge spikes towards the opposite polarity. I couldn’t prevent this by choosing any of the 3 interpolation methods or with/without Smooth being set. It seems to be when the value is at exactly 1 or -1.
I had to opt for a work-around and multiply the array by 0.99 to fix it. It’s worked on all the wavs I’ve tested so below is the link to the new version v1.004. This is a complete download to replace the previous one and I’ve amended the link in the original post.
Sorry if anyone’s had this issue and please tell me if you find any others.
Spogg - Posts: 3323
Dude this tool was cool !!!!!!!!!!!!!! amazing man! very usefull!
- djbrynte
djbrynte wrote:Dude this tool was cool !!!!!!!!!!!!!! amazing man! very usefull!
Thank you
Spogg - Posts: 3323
I like this idea; But do You think there might be better; more intuitive labels for the buttons?
The only part that threw Me off. Also the update sample is confusing.
Maybe like a list box of buttons purposefully grouped like radio toggles? loaded, captured and etc?
Thanks Spogg. BTW I was going to offer to make a GUI for You; But I like Yours to be honest.
Maybe a rounded edge here or there but Coo.
Thank you for your comments sir!
These days I like to keep my labels short. I got a comment from a guy who had visual difficulties and he appreciated using more concise labels and in capitals. Easier for him to read apparently.
I do try to choose labels that are as descriptive as I possibly can, but ultimately I think it’s about learning what they do by using it. I guess that goes for any new tool or plugin. I know I find it quite a challenge,initially, on most new professional products I try out. Where to begin? What does that actually do? How do I do what I have in mind?
The GUI part is a real challenge for me but I know it’s very important to encourage and assist use; to make things as clear as possible and for the layout to help workflow. So these days I do put thought and time into it but I’m always open to suggestions, especially so because it's a weak skill area for me.
Spogg - Posts: 3323
