2SYNts- regular guitar to poly synth
Re: 2SYN-hex MIDI guitar!+synth
I fixed ver 1_8 pretty much I think.
Update is in the first post.
nJoy!
nJoy!
nix - Posts: 817
Heya-
still working on this. It's going good, and plays nicely now.
Updated .fsm is in the first post, and the slightly modified UI.
nJoy!
nJoy!
nix - Posts: 817
Oh yeah,
here are some new resources->
logo->
new demos->
https://soundcloud.com/nix808/pwm-cheetah
https://soundcloud.com/nix808/2synpiano2017
logo->
new demos->
nix - Posts: 817
Hey Nix , is this available somewhere ? The sendspace link is dead.
lalalandsynth - Posts: 600
here's the MIDI one currently->
(edit)-- sorry, I've pulled this, wanna have a commercial go at this now
it's for FS v3081
It's simpler and the graphics are a bit more funky
I have been testing heaps.
I made a amplitude filter for it-
seems to help a little.
It's an expander.
I also maximised sustain- that's about it for sustain prolly- the bleeding makes other strings fire,
but I have used a MIDI switch thingy to fix that a bit before,
let me know if you want the 'last off' switch
--(edit) it 's so nice you're interested, please hit me up with feedback if you have any questions or improvements
it's for FS v3081
It's an expander.
nix - Posts: 817
new version up in first post.
I think the bend mode is working as should now-
trig still plays the wrong note sometimes- but it's close too
njoy!
njoy!
nix - Posts: 817
Hi 8D --
I have got this as good as I can do it on VSTfx x86 built in FS.
The bend and trigger modes both work darn well.
This update is only for the FS build- which will be x64 this year.
Known issues->
playing deliberate harmonics freak it out.
If u accidentally play a harmonic the same sorta warbly result can happen.
A lot of mispitched information is discarded in trig mode, so there is a small chance it will play the wrong note(most likely a semi out).
The build is heavy on CPU, I am no code genius, so I will ask friends if they can help optimize it.
The build leaks RAM slowly. This is due to being built in FlowStone 3081. I have a FS build that doesn't leak though, so if u play for more than 24 hours straight- I have the elixir which will keep u up!!-- just let me know. 3081 is used for it is stable and lets me share the source.
Novel subtle device now employed->
I have made a new device in this one. Have a look at the 48db hp cascade which is subtracted. It now is also active before the rest of the cutoff circuit. This means it parts the signal before the bulk of the harmonic reduction is done. so it cleans the harmonic before it is audible, or alters the cut value.
old novel device->
polypole filters created by mixing different cascade orders. These are the harmonic controls on the UI. Screw with these last when making ur master preset. Prolly they can't be a whole lot better for an active GK3. CyCfi pickups may be different-haven't tried them. Ubertar pickups honestly bleed too much between strings for the top half of the fretboard, although I have 2 nice guitars outfitted with them.
Rock on and move my d/l counter. Any comment muchly appreciated!
There will be more releases of this soon as far as the synth,Reaktor build and 64 bit VSTs, first jBridge then native
u can find the update in the first post of the thread
Known issues->
old novel device->
nix - Posts: 817
nix im trying to contact u everywhere.
- djbrynte
Johhie found me!
v1985 up in first post. It's finished
It plays real nice, nearly like it was made of switches, not the analog sensor
nix - Posts: 817
v196 up-
now using a smoothed sine osc to feed the pitch counter
I'll tackle the regular tr pickup now
nix - Posts: 817
Users browsing this forum: Google [Bot] and 31 guests
