Bobs Wave Slider Synth
Hello gang,
Here is my 3rd Synth. It is called the Wave Slider Synth because the big difference with the oscillators is that you can slide the positive part of the waveform while the negative part stays stationary. I have provided you all with 25 presets to get you started and also do please read the manual (rar file), it tells all.
Have fun and please if you create any new presets please post them along with any suggestions, bug fixes, and so on.
Later then, BobF.....
- Bobs_WaveSlider.fsm
- (405.13 KiB) Downloaded 977 times
- BobF
Re: Bobs Wave Slider Synth
HELP ! It's been reported already that this synth can only be made into a EXE and NOT a DLL.
Does anyone see the reason this would be so?
Thanks all.....
FIXED
Thanks all.....
FIXED
- BobF
BobF wrote:HELP ! It's been reported already that this synth can only be made into a EXE and NOT a DLL.
Thanks all.....
You can not export it in VST because there are no midi inputs or mono outputs. Here is the schematic with input and outputs.
- BobsWaveSlider_inputs.fsm
- (405.13 KiB) Downloaded 998 times
- Wassaka
Thanks Wassaka ,
Must have been a senior moment.....
- BobF
Hi Bob
Yet another interesting technique!
I quickly tried the presets and I'm impressed but I will spend a bit more time with it on my return.
The GUI colour makes it look more "modern" somehow too.
Thanks for sharing and your stuff is always inspiring.
Spogg - Posts: 3323
Users browsing this forum: Google [Bot] and 15 guests
