Non audio-card DSP hardware
Postby marcelodantas » Fri Nov 10, 2017 3:02 pm
Hi everyone,
Is there a hardware which could be used with flowstone for DSP signal generation and acquisition, but on frequencies higher than the audio scale? Maybe also with arbitrary voltage ranges?
I want to see if it is possible to use flowstone to design a signal generator and oscilloscope for signals above audio frequency.
The hardwares I saw for data acquisition so far seem to work only on much lower frequencies.
I am thinking about a logic analyzer as well, which should be already possible to make.
Thanks,
Marcelo.
marcelodantas
Re: Non audio-card DSP hardware
Postby KG_is_back » Fri Nov 10, 2017 4:04 pm
Google ultrasound recorders... they might be just what you're looking for. Also, many regular audio interfaces support sampling frequencies up to 192kHz, however, they usually have a build in low-pass filter @20kHz and these high-frequency modes are mostly to prevent aliasing from ultrasonic frequencies so sound that they pass through the filter.
KG_is_back
Return to DSP
