Process an Array in Ruby
Postby OllieMarshall92 » Tue Oct 18, 2016 8:26 am
Hi All,
Basically I want to find the sin([array]) (sine of each value in the array) and then export the array from ruby.
I can find the sine of a float but my code wont do the same to an array. Ruby comes up with an error something like "cant convert array to float".
I think I may need to iterate through the array, processing one at a time but I cant work out how to do that.
Ollie
OllieMarshall92
Re: Process an Array in Ruby
Postby tulamide » Tue Oct 18, 2016 9:00 am
With "myarr" as the array that contains the data
na = myarr.map { |v| Math.sin(v) }
Postby Lex248 » Tue Oct 18, 2016 9:56 am
With RAD2DEG and RAD2GRAD module.
sin_array_1.fsm
(486 Bytes) Downloaded 413 times
sin_array_2.fsm
(534 Bytes) Downloaded 403 times
Sorry, I bad speak english.
My plug-ins http://nalexsoft.blogspot.com/
Lex248
Postby OllieMarshall92 » Tue Oct 18, 2016 10:26 am
Thanks, both of you.
My input is in degrees, how do I format it so if I put 180 in I get a 0 out? e.g. sin(180) = 0
Ollie
OllieMarshall92
Postby Lex248 » Tue Oct 18, 2016 12:42 pm
Lex248
Return to DSP
cron
