Need some help with this Code
Postby Father » Fri Oct 28, 2016 5:20 am
Hi
I was analyzing some parts of a compressor. I need some help understanding it so maybe i could do it in C++.
Maybe someone can answer these questions for me.
a) Whats the goal with the 'Level' module (inside Transfer)? Whats happening in stage 0 and 2?
b) Can't we do all the 'Transfer' module all in green? After all the output is a float array.
c) And if you have experience maybe some helpers with the actual codes.
Thanks.
level.fsm
(3.95 KiB) Downloaded 435 times
Father
Re: Need some help with this Code
Postby TheOm » Fri Oct 28, 2016 11:00 am
Father wrote:a) Whats the goal with the 'Level' module (inside Transfer)? Whats happening in stage 0 and 2?
It's just a linear ramp from some start level (-96dB) that reaches a target level (0dB) after 2048 samples.
stage 0 initializes the accumulator variable "count" with the start level.
stage 2 just adds the precalculated value "add" to the accumulator each sample
Father wrote:b) Can't we do all the 'Transfer' module all in green? After all the output is a float array.
Yes it could be done in green or ruby.
TheOm
Postby Father » Fri Oct 28, 2016 3:39 pm
Hey TheOm
Correct me if i'm wrong, stage 2 (Count = Count+add) is being called for each sample, so its a loop like this:
count = init;
for (int i=0; i<Sample_Rate; i++)
output_array[i] = count+add;
At the end the 'Analyser' prime takes 2048 samples from that. So we need to use a interpolate function to resample it to a new array with a size of 2048.
My confusion is about the stream code. How many times does 'Count = Count+add' is being executed? Sample Rate right?
If we want to do the loop for 2048 times, do we need to change the 'add' value too?
Father
Postby TheOm » Fri Oct 28, 2016 7:09 pm
That's not quite correct. The sample rate is not involved at all actually.
First stage 0 is executed exactly once.
Then stage 2 is executed 2048 times (or however much you specified on the Analyzer prim).
This would be the analogous C code:
float count = init;
for(int i = 0; i < 2048; i++) {
    output[i] = count;
    count += add;
TheOm
Re: Need some help with this Code [solved]
Postby Father » Fri Oct 28, 2016 9:42 pm
TheOm wrote:That's not quite correct. The sample rate is not involved at all actually.
Oh i get it now. Thanks!
Now about the read out module.
I don't have the original dsp code for the part that produces the IndexA, IndexB and Modulus. from assembly code i gather this:
streamin base; streamout indexA; streamout indexB; streamout modulus;
intindex = whatever happens to(base-0.5);
indexA = intindex;
indexB= indexA+1;
modulus = base-intindex;
that 'whatever happens' i didn't get was this part:
movaps smIntVarTemp,xmm0;
fld smIntVarTemp[0];
frndint;
fstp smIntVarTemp[0];
fld smIntVarTemp[1];
frndint;
fstp smIntVarTemp[1];
fld smIntVarTemp[2];
frndint;
fstp smIntVarTemp[2];
fld smIntVarTemp[3];
frndint;
fstp smIntVarTemp[3];
movaps xmm0,smIntVarTemp;
What happens here?
There are some crossing channels and stuff like that i don't understand exactly. Some seem unnecessary..
Father
Postby TheOm » Sat Oct 29, 2016 2:20 pm
That readout module is a simple linear interpolation table lookup module.
Father wrote:that 'whatever happens' i didn't get was this part:
frndint;
frndint;
frndint;
frndint;
What happens here?
This is the old (pre SSE2) way of flooring an sse register. It floors the 4 floats seperately on the x87 float stack.
This is inefficient. Today you would just do
cvtps2dq xmm0, xmm0
cvtdq2ps xmm0, xmm0
The code looks like it comes completely unaltered from the output of a DSPCode Module.
The unpack-pack business should better be done with shufps instructions.
It's done to get the value in the table at IndexA into the lower 2 floats and the value at IndexB(which is just IndexA + 1) into the upper two floats.
Then the linear interpolation between the values is done in the X-fade module.
TheOm
Postby Father » Sat Oct 29, 2016 10:58 pm
Ok let me see if i got it right, if that means just rounding to int basically we have to this in read out:
IndexA = RoundToInt[(Base*2048+1)-0.5];
IndexB = IndexA+1;
Modulu = Base - IndexA;
Readout = ArrayFromTransfer[Index a] * (1-Modulu) + ArrayFromTransfer[Index b] * Modulu
I'm guessing 'wave read' prim does something like index=max(input_index, array_size) so we also need a max(base,1) at the beginning.
Father
Postby TheOm » Sun Oct 30, 2016 6:38 pm
Yes that's almost correct. Just a small mistake.
temp = (Base*2048+1)
IndexA = RoundToInt[temp-0.5];
IndexB = IndexA+1;
Modulu = temp - IndexA;
Readout = ArrayFromTransfer[IndexA] * (1-Modulu) + ArrayFromTransfer[IndexB] * Modulu
Father wrote:I'm guessing 'wave read' prim does something like index=max(input_index, array_size) so we also need a max(base,1) at the beginning.
I think you mean index=min(input_index, array_size - 1) and min(base, 1.0).
However, even if you clamp base to be less or equal to 1.0 the highest index that the code tries to access would still be 2048 + 1 + 1 (=2050).
I'm not sure what the point of the "+ 1" in "Base*2048+1" is to be honest.
TheOm
Re: Compressor - Need some help with the Code
Postby Father » Mon Oct 31, 2016 11:29 pm
TheOm wrote:Yes that's almost correct. Just a small mistake.
You are right. I make those kind of mistakes all the time.
I finished rewriting the codes and its kind of working. There are few bugs crashing it, which i have to find.
After that I'll check if the outputs from both plug-ins are close enough.
Thanks so much for the help TheOm, appreciate it.
Father
Return to DSP
cron
