Can I make License file for Flowstone VST like Sylenth
Re: Can I make License file for Flowstone VST like Sylenth
Postby DaveyBoy » Tue Apr 11, 2017 10:18 pm
DaveyBoy
Postby djcrazyvdj » Wed Apr 12, 2017 6:47 pm
Thank you RDGAudio for the code. :)
DJ Crazy
djcrazyvdj
Postby djcrazyvdj » Fri Apr 14, 2017 6:16 am
Making a keyfile is possible by this way but my problem is every time I have to register with the keyfile. When I exit from the app/vst everything becomes demo.Asks for keyfile every time. So, in Flowstone is there any process to register key into windows memory/registry? Or make it permanent? Otherwise keyfile will be a nightmare for end user . :roll:
by,
DJ Crazy
DJ Crazy
djcrazyvdj
Postby nix » Fri Apr 14, 2017 7:38 am
If you have a keyfile as a file,
ask your user to put it in the same place for different user's systems.
Like on C:
When the program runs, use 'on load' to look up the keyfile and see if it's right.
How does that sound people?
nix
Postby RJHollins » Fri Apr 14, 2017 7:44 am
I put them in the same folder as the app or plug. There is a PRIM that can look there specifically. Load the text file when app/plug is launched.
As for the Registry ... I seem to remember an experimental PRIM or routine in one of the 'toolbox' collections back in the SM days.
Postby djcrazyvdj » Fri Apr 14, 2017 3:14 pm
Nope guys, the keyfile location same as program location not working. How to use On Load?
DJ Crazy
djcrazyvdj
Postby nix » Fri Apr 14, 2017 9:49 pm
I imagine you need to trigger, then automate your registry procedure-
using the trigger that comes out of 'on load' or 'after load' whatever it's called.
So to start with, use the on load trigger for the registration dialogue.
It should pop the dialog automatically, then you will need to automate rest of the steps to enter the code
The 'plugin folder' is just perfect, will need to remember this prim
nix
Previous
Return to DSP
