Re: Bitmasking in DSP Code
Posted: Wed Sep 27, 2017 9:38 am
I found DSP difficult to understand, and I still have to experiment until I get the intended outcome. If something even simple works first time, it’s a cause for immediately getting a coffee to celebrate.
But in my case I don’t think about the bit masking itself. I’ve kinda learnt the syntax of what to do to get what I want, and I never refer to the process under the hood. I look at work by others and try to figure out what’s going on. I remember totally struggling to modify an AHD envelope generator to work in sample increments rather than 16-sample hops. I got there but never once thought about bit masking. And that applies to literally all my DSP modules.
The only time I found it necessary to think about it was Martin’s tutorial, in relation to the abs alternative. This method was very odd to me but happily it makes sense to me now, but of course I could use it without remembering the explanation itself.
I think the method of learning that I’m proposing goes against the grain for you though. I personally find favour with top-down learning to some extent, with a lot of trial and much error. I like to learn what to do to get what I want and worry about what’s behind it all only when necessary or interesting. This is a bit like a child learning a language, they make certain noises and when they get it right, or good enough, stuff happens. It gets more polished as they practice.
On the technical reason for bit masking I believe that it’s simply faster and so more CPU efficient than conditional branching etc. but I hope Martin will correct me if that’s not right.
