Phidget sample rate
Discuss robotics applications using FlowStone here
Phidget sample rate
Postby julik_v » Fri Oct 02, 2015 1:22 pm
Hi there
I use the Phidget modules, and it works great. However, it seems that there is no option to set the sampling rate.
As-is it is 50hZ, but the Phidget modules are capable of much higher rates. How can I configure this in FlowStone?
J.
julik_v
Phidget sample rate
Postby Bowkew » Mon Oct 07, 2019 5:16 pm
Im using the AC3 passthrough via the A52 Codec which requires the sample rate to match on the movie and audio output interface for it to work. My videos all use a sample rate of 48KHz, so I set this in Audio MIDI Setup for my digital out. However, every time I restart the setting is lost and is set to 44KHz. Does anyone know how to make it stick at 48KHz?
Bowkew
Return to Robotics
