Great tool for File/Folder Deletion..
Postby billv » Fri Nov 15, 2013 3:40 am
In the course of de-bugging a virus, I needed to delete
Suspicious files, and got some ‘access denied” shit…so
Went for a search…found an absolutely incredible little
Tool….feels like xmas came early…. :D
“Unlocker”
http://www.emptyloop.com/unlocker/
This little bugger will un-lock any file, so it can be
renamed and deleted.
It even deleted my “RECYCLER” folder,
and I’ve been trying for years to clean that section out.
Great thing too is during install it provides an option
To put Unlocker in your ‘right-click”menu….
So you you can go hunting and process dodgy files
On the spot when you find them…
It has not failed once to process a file/folder…. :!:
BV MUSIC SYDNEY AUSTRALIA-Songwriting & Software Development.
http://users.tpg.com.au/billv
Re: Great tool for File/Folder Deletion..
Postby jjs » Sun Nov 17, 2013 8:40 pm
great !
sometimes for no good reason you as admin of your own pc can't delete something.
this is a good solution
jjs
Postby tester » Sun Nov 17, 2013 9:07 pm
Yep. I use it for years.
There are also helpers for Windows copy/paste/move operations, so you can pause or filter better when overwriting or manage transfer (and measure real transfer).
I always wonder why such tools are not present by default in the system.
Need to take a break? Looking for relaxing sounds? I have something right for you.
(by purchasing, you are also supporting further development of related projects).
Thank you for your contribution.
deleted by uploader
Postby tiffy » Thu Dec 12, 2013 3:40 pm
deleted
There is no glory in practice but there is no glory without practice.
tiffy
deleted by uploader
Postby tiffy » Thu Dec 12, 2013 3:55 pm
deleted
tiffy
Postby tester » Thu Dec 12, 2013 5:58 pm
They are not that bad. :mrgreen:
Any world wide big company is being considered as "bad", because nobody (i.e. ordinary web people with expectations) likes global domination. On the other hand - without global domination - market is fragmented. If I had option to select between operating systems (MacOS or whatever names they use for laptops/desktops, Win, Linux, iOS, Android, etc) - I would pick Windows (98, XP, 7). It's simple - more tools that I use and not that bad stability & performance, better compatibility with others around me (we are MS region here). If I would want more, then I would end up with less tools and problems more difficult to solve without knowledge or someone to ask.
Postby trogluddite » Fri Dec 13, 2013 6:56 pm
tester wrote:They are not that bad.
I've no sympathy for them as a corporation bent on monopoly, but the programmers you have to feel some sympathy for - summed up nicely here...
Seven reasons why computer glitches wont go away - ever!
Thanks to all for the software tips - you can never have too many little gizmo's like that. :)
Postby tester » Fri Dec 13, 2013 7:03 pm
Yep, a good summary.
Return to Off Topic
Users browsing this forum: agrohimmtl and 3 guests
