Page 2 of 3
Re: Ruby for noobs!
Posted: Mon Jan 21, 2013 6:52 pm
by trogluddite
Nubeat7 wrote:...is the load and save state needful in this example to work correct with a presetmanager?
Not any reason that I can see - the input and output values of the Ruby prim' are always stored anyway - but that will only affect the values when you first load a 'clean' copy of the plugin - once it's in a song, the preset manager should just take over.
Might help to keep the handle synce'd with the output values at load time though, so I wouldn't scrap them.
Couple of other little things I just noticed...
- With the drag behaviour changed, @x and @y aren't needed in the mouse routines any more - they get defined in the 'draw' method anyway..
- The 'event' parts for the 'set' input values could do with redraws, otherwise the handle may not move when you send preset values into them.
Re: Ruby for noobs!
Posted: Sun Jan 27, 2013 3:48 pm
by Nubeat7
ok, i included preset parameters to use it with presetmanager, so XY Pad is finished now.
hope it is a good help for ruby noobs to understand some things bit better..
Re: Ruby for noobs!
Posted: Sun Jan 27, 2013 6:49 pm
by pall
Thanks Nubeat!
But...
If you apply value 1 to the set y input, the y output is 0, and vice versa.
I do not know ... That's right? ;)
Re: Ruby for noobs!
Posted: Sun Jan 27, 2013 9:28 pm
by Nubeat7
[url][/url]oh, yeah i left a challenge! ;) .....
if i==10
		@valy = [0,1-v,1].sort[1]
		output 1, 1-@valy
		redraw
forgot the 1- before the value, there was a similar bug in the FS 3.0 stock slider....
should work right now! i reuploaded the FSM...
its just one thing left, it don`t redraw the position when setting it with the presetmanager?? hmm
Re: Ruby for noobs!
Posted: Sun Jan 27, 2013 11:10 pm
by Nubeat7
normally the preset module should send set value when doing a presetchange but this is not happening, sadly i cannot say why.... when watching the stock slider it is working but everything is the same inside the preset module, or?
Re: Ruby for noobs!
Posted: Mon Jan 28, 2013 2:21 pm
by Walter Sommerfeld
Hi Nubeat7,
have a look @ the Interact Bool,
def mouseMoveCaptured x,y => output 2 is always TRUE...
Re: Ruby for noobs!
Posted: Mon Jan 28, 2013 7:11 pm
by Nubeat7
Walter Sommerfeld wrote:Hi Nubeat7,
the missing code:
def mouseLUpCaptured x,y
	output 2,false
	releaseMouse
thank you walter! shure when i dont tell ruby that it should be false when finish the mouse action, it cannotwork correct! :oops: ... so reuploaded again! now it really should work correctly :)
i also deleted the triggerswitches inside the preset module to make manual set val possible..
Re: Ruby for noobs!
Posted: Wed Feb 06, 2013 10:26 pm
by Nubeat7
i thightened the code a bit and fixed a little bug : interact was turning true in the mousemovecaptured section - only when moving - now it turns true when leftmousebuttondown, so it reacts already when you click in the mousearea
Re: Ruby for noobs!
Posted: Sun Feb 10, 2013 12:02 pm
Hmm,
none of ur versions sets the right Preset after changes with the arrows...
Saving the param works and its only correctly set (placed on GUI coordinates) after reload the preset...
damn - i hate doing this :oops:
Re: Ruby for noobs!
Posted: Sun Feb 10, 2013 10:25 pm
by Nubeat7
hmm, you checked the latest version too (xy pad 01) ? because it works here on my pc... i downloaded it and added a presetmanager and everything workes right the the coordinates and the values as well!
anyway it sounds weird because when changing a preset the presetparameter prim sends the values directly to the outputs and also to the ruby to set the position as well so when it sets the position right it has to set the values right as well because the datas are from the same source - the current value output of the presetparameter primitive! the only situation where this is happening is when you set the values from outside because before the value from the rubymodule arrives the presetparameter prim there is a triggerswitch which allows signals only while mouseinteract is true but when setting from outside it is false because there is no mouseaction... because of that i removed this option but it could easily added again, just add a lastswitch after the triggerswitch for setting values from outside similar to the one for midicc
