Thk martin for reply
Martin I have only audio distorted as out of autovolume, anyway based on what I see your project is targeted to down the volume upon peak, very nice and good, and verynear of what I need.
Anyway what I trying to do is a more complex I think, I need automatic volume control for act as soft leveler.
Imagine I want do make compliant the audio to EBU R 128, can be any other normalization in this case I choose EBU R128, where max output program should be -23lufs with tolerance of +- 1LU
So the idea is create a limiter, can be adjusted to any STANDARD, like EBU R128, so I can adjust audio program in real time, with less possible noticiable audio artifacts.
The volume should go up and down all the time in a soft way for prevent at maximum audio artifacts, but need recover the volume if the audio material incoming is a lot dow under -23 and volume of audio material must go down when is over of target volume, in this case -23LUFS
Probably what I need is a very faster compressor/lmiter/acg lol?
BS1770 (rev.3), EBU R128, ATSC A/85 and many more are similar standard where the BS1770 (rev.3), EBU R128 are adopted now worldwide.
The audio industry already adopt lufs as metering and very soon LUFST will be what we talk, not any other meter.
I really suggest guys start to talk in LUFS as reference for all.
Broadcast industry already do, now music industry is following.
The new real 0db for audio will be -23lufs, already is for broadcast and music industry is moving faster in this new direction.
For audio industry take some time, is very complex jump form the current volumes to -23lufs but audio industy is already moving, really not have sense master clipping to 0db, and then your music, is LIMITED AND RECRUNCHED due limitation on TVS, Radio Stations, IOS devices, when audio check, Spotify, etc.
What I try to do is a audio NORMALIZER or can be called limiter too lol, on radio stations audio limiters do this in really very good way, ORBAN processors , some commercial software, etc can do this in real-time.
My problem is I think the math involved locate to me really out of this.
The RMS limiter from you martin do super good job, is very near to do what I want achieve, but I listen very noticiable audio artifacts, distortion, don't know if can be improved and for sure if can work with LUFS instead dbs.
Finally, again I repeat, I think will be a good practice start to talk in LUFS and LU
Very nice job form Youlean here:
http://www.dsprobotics.com/support/view ... f=3&t=3018
Act as compartator, just enter a stereo signal to both inputs and you have a real INTEGRATED LUFS meter super accurate.
Sorry this not is directly related to audio limiter, but very nice project related to LUFS
Mmmm I love to see your autovolume working with adjustable target in lufs instead to peak, and with some autorecover logic
