Page 3 of 3
Re: Sample Player midi problem
Posted: Sat Jan 16, 2021 6:05 pm
by josevo
newdsp wrote:If you look at this sampler you can detune or change octaves by changing the root key note but you can also transpose from the midi side. You can also check how the pitch bend works in Chaos. Chaos also has octave shifting and detune. The problem with the mono sampler is that it doesn't have any envelopes and if you want to add 16 or 32 envelopes or a separate envelope for each sampler it can overload the CPU. Most of them use Midi-To-Voices so I don't know which one is supposed to be different.
Don't expect too much answers, all these examples are crashing.
What versions of flowstone are you using here, please?
Posted: Sun Jan 17, 2021 4:41 pm
by newdsp
All my example are saved using v3.0.9b2-3319-gd51130b but the FL examples are from FL Synthmaker and those don't work with v3.0.9b2-3319-gd51130b. They might work in FS 3.0.6 or 3.0.0 but I have no way to test if they open or not at the moment.
Posted: Mon Jan 18, 2021 7:30 am
by StereoSpace
I use v3.0.9b2-3305
Everything works great. (as for the examples posted here)
Posted: Mon Jan 18, 2021 6:14 pm
by josevo
I'm using skylark 3.0.8.1 (32 bits) because it's stable enough for my needs, sorry.
Thank you all!
