Page 4 of 5
Re: PositionSyncedStepLFO - help?
Posted: Sun Jan 12, 2014 4:41 pm
by Nubeat7
optimized the code to get rid of the modulo division, and further optimizing in assembly..
edit: check first file for latest version!
Posted: Mon Jan 13, 2014 12:15 pm
by Father
This one starts on load, not when 'is playing' so it's out of sync.
I also noticed the smooth knob doesn't work, It's not effecting the audio as it should. (in previous version too).
Posted: Mon Jan 13, 2014 8:57 pm
by Nubeat7
did you unwire the pseudo host inside the ppq sync module? there you need to connect the timesig from host and the host ppq primitive, i was using a pseudohost module for testing inside FS, forgot to unwire this
about the smooth, thanks! there was a mistake in the code of the ruby stepsequencer, thanks for figuring this out.
fixed both things and reuploaded the last version
Posted: Mon Jan 13, 2014 11:40 pm
by Father
Sorry my bad! I didn't really look, was kinda busy, I knew it's something like that, happens a lot. It's fixed now.
I think steps height needs a bit correction. Because in positive mode there is a bit extra at bottom of every step, or rather there isn't a fixed line there.
I just tried this for a quick fix. added a 0.1 to height.
#--------draw Bars------------------#
@steps.times do |id|
if @positive
y = @h - @h*@Values[id]+0.1
h = @h+0.1
Re: Position Synced StepLFO
Posted: Fri May 29, 2015 9:19 pm
by Nubeat7
updated to the latest version in the first post, including the fl studio ppq fix which was discussed here:
http://www.dsprobotics.com/support/view ... d&start=30
Posted: Fri May 29, 2015 9:28 pm
by Father
Do we have a solution to identify the DAW yet? Its really unprofessional to ask users to choose if they are using FL studio or not.
Posted: Fri May 29, 2015 9:35 pm
by Nubeat7
no, there is no solution...
Posted: Fri May 29, 2015 9:40 pm
by Nubeat7
but i think 99% of FL user's don't use any other timings than 4/4..
Posted: Fri May 29, 2015 9:44 pm
by Father
Nubeat7 wrote:no, there is no solution...
True but they should really consider it on the next update, among other useful vst functions that's been missing.
Posted: Mon Jun 01, 2015 12:12 am
by Perfect Human Interface
Father wrote:Nubeat7 wrote:no, there is no solution...
If you are one the IL forums you should post there about it. While they certainly may not do it just because you asked for it, they do listen closely to customer suggestions and most of their updates are based on customer feedback.
