Page 33 of 58
Re: Synthmaker bundle
Posted: Tue Jan 31, 2017 7:18 am
by RJHollins
You, Sir ... are amazing.
I'm not much involved with the synth world ... but I, nonetheless, respect 8-)
Posted: Tue Jan 31, 2017 9:55 am
by k brown
Well, thanks.
Are you more involved with the robotics side of things around here?
Posted: Tue Jan 31, 2017 11:22 am
by RJHollins
no ... I work Mastering audio [along with some mixing].
My involvement with SM/FS have been special MIDI utilities, controller GUI to handle up to 16 other VST plugins.
Other than that, a little dabble in special audio processing utilities.
All basically tools to assist my workflow.
Posted: Wed Feb 01, 2017 9:09 pm
by k brown
For those who may be using tonus Pro Colorist - there's been a minor update; fixed a few errors.
-PWM changed to positive-going only; sounds better.
-AT/Wheel Vibrato can toggle to Tremolo (was done internally on the Pro Soloist's presets).
-Noise was inadvertently pre-filtered.
-Included four simple presets (NOT emulations of the PS's sounds).
Hang onto the first version if you've made presets for it; new version is identified as "tonus ProColorist b".
Posted: Thu Feb 02, 2017 7:12 am
by k brown
Sorry for the confusion folks - go get it again; found a couple more things. Mainly put Pitch Bend back onto the row of performance controls where I'd put PWM. Now that button toggles P-Bend/PWM. Your MIDI bend wheel will still do +/- a fifth.
Posted: Thu Feb 02, 2017 8:40 am
by k brown
Tinker, tinker - can't leave well enough alone.
A version of tonus Explorer to which has been added several of the aftertouch (or mod wheel) controls from the Pro Soloist. In this case though, each has it's own dedicated sensitivity control.
tonus Explorer AT :
tonus Explorer AT.jpg (115.21 KiB) Viewed 35629 times
In it's own sub-folder in the Explorer II folder.
Posted: Sat Feb 04, 2017 1:57 am
by k brown
Sittin' there staring at CS75M and looking at the amount of panel space devoted to the stepLFO that I don't care much for and use very little - just cried out for that space to given to an additional oscillator per synthline, one of the more frustrating things about the CS-series instruments is the single oscillator in each channel. So that gives us:
Yumaha CS78F :
Yumaha CS78F_copy.jpg (78.44 KiB) Viewed 35613 times
Name derived from the GUI borrowed from CS-'8'0 and the fact that it has 'F'our oscillators.
Posted: Sat Feb 04, 2017 8:41 pm
by DrewDale
Great work on the updates Kevin, also top class work on the CS78F. Can imagine creating some decent patches for this one. :D
Posted: Sun Feb 05, 2017 10:43 am
by k brown
Thanks, - any chance you would share some of your patches?
Posted: Mon Feb 06, 2017 1:36 am
by k brown
Doesn't seem to be a great appetite around these parts for modular-based stuff, but here's another based on a small ARP 2500 system. It was described in one of their brochures as "Sample System 6", their smallest.
Lots of envelopes, three oscillators, three filters (two are multimode); of particular note is the module second from the right, called a 'Voice'. - it's basically a complete synth in one module: VCO, VCF wEG, VCA wEG.
Patching by drop-downs at each input - I did actually attempt an emulation the switch-matrix patching, but it drove me nuts; sluggish and hard to follow visually what's patched to what on a computer screen.
tonus System 6 :
tonus System 6_copy.jpg (133.99 KiB) Viewed 35539 times
The only deviation from the module compliment of the Sample System 6 is the swapping out of the Modamp with an approximation of the Filtamp (with added ring mod).
