Page 5 of 6
Re: Elektron Digitone
Posted: Tue Dec 21, 2021 9:55 am
by k brown
Sorry, I probably should have just posted this to begin with.
FlowTone v1.000.fsm.zip
(1.23 MiB) Downloaded 989 times
Posted: Fri Dec 24, 2021 1:02 pm
by Spogg
I’ve modified the switching scheme for FEG/BRTH a bit and added a comment box. I think it’s ok now, even though my fix isn’t too elegant. I didn’t want to change stuff too much.
Just needs a few hundred presets now! ;) :lol:
Posted: Fri Dec 24, 2021 11:00 pm
by k brown
Thanks tons - that certainly does the trick! I'm sure that solution would never have occurred to me.
Time for v1.001, I think. Have done a few more control range refinements, and added indicators above each mod source selector button that show when something is being modulated by that source (since not all mod controls are visible at once).
FlowTone v1.003.fsm.zip
(1.27 MiB) Downloaded 874 times
FlowTone copy.jpg (160.25 KiB) Viewed 34161 times
Posted: Sun Jan 02, 2022 9:09 am
by k brown
Added schematic and image to the previous post.
Posted: Tue Jan 04, 2022 12:23 pm
by Spogg
Really coming on now!
I do hope you plan to make some presets for it when you declare it finished... ;)
Posted: Sun Jan 09, 2022 4:25 pm
by Duckett
Here's at least one preset (.txt not allowed, imho not worth zipping, just copy and paste, save as .txt) ;)
Preset Table Format
Number of programs = 1
Number of parameters = 118
Parameter Type BOCBass
LFO 1-Type Float 0.142857
LFO 1-Rate Float 0.834125
LFO 1-Phase Float 0.363000
LFO 1-sync on/off Float 0.000000
LFO 1-Fade Float 0.234375
LFO 1-Speed Mult Float 0.833333
LFO 1-Depth Float 1.000000
LFO 1-Dest Float 0.050000
LFO 1-Mode Float 0.200000
LFO 1-C Offset Float 0.963750
LFO 1-C Offset Float 0.307500
LFO 1-C Offset Float 0.836250
LFO 2-Type Float 0.571429
LFO 2-Rate Float 0.610500
LFO 2-Phase Float 0.338250
LFO 2-LFO sync on/off Float 0.000000
LFO 2-Fade Float 0.626562
LFO 2-Speed Mult Float 0.714286
LFO 2-Dest Float 0.000000
LFO 2-Mode Float 0.400000
LFO 2-Depth Float 0.142857
LFO 2-C Offset Float 0.680625
LFO 2-C Offset Float 0.520625
LFO 2-C Offset Float 0.237500
View buttons front panel Float 0.200000
M-Whl-Dpth1 Float 0.149375
M-Whl-Slct 1 Float 0.100000
M-Whl-Dpth2 Float 0.273125
M-Whl-Slct 2 Float 0.050000
M-Whl-Dpth3 Float 0.075125
M-Whl-Slct 3 Float 0.000000
M-Whl-Dpth4 Float 0.000000
M-Whl-Slct 4 Float 0.350000
P-Whl-Slct 4 Float 0.950000
P-Whl-Dpth4 Float 0.500000
P-Whl-Dpth3 Float 0.500000
P-Whl-Slct 3 Float 0.950000
P-Whl-Dpth2 Float 0.500000
P-Whl-Slct 2 Float 0.950000
P-Whl-Dpth1 Float 0.500000
P-Whl-Slct 1 Float 0.950000
Velo-Slct 4 Float 0.750000
Velo-Dpth4 Float 1.000000
Velo-Dpth3 Float 0.648500
Velo-Slct 3 Float 0.200000
Velo-Dpth2 Float 0.104000
Velo-Slct 2 Float 0.800000
Velo-Dpth1 Float 0.318500
Velo-Slct 1 Float 0.800000
Atch-Slct 4 Float 0.950000
Atch-Dpth4 Float 0.500000
Atch-Dpth3 Float 0.500000
Atch-Slct 3 Float 0.950000
Atch-Dpth2 Float 0.500000
Atch-Slct 2 Float 0.950000
Atch-Dpth1 Float 0.500000
Atch-Slct 1 Float 0.950000
Brth-Slct 4 Float 0.950000
Brth-Dpth4 Float 0.500000
Brth-Dpth3 Float 0.500000
Brth-Slct 3 Float 0.950000
Brth-Dpth2 Float 0.500000
Brth-Slct 2 Float 0.950000
Brth-Dpth1 Float 0.500000
Brth-Slct 1 Float 0.950000
Mod-Brth/FEG Slct Float 0.000000
Poly/Mono Float 0.500000
Portamento Float 0.078375
Bend Range Float 0.250000
Global velocity Float 0.333333
Global A-Touch Float 0.333333
Transpose Float 0.250000
Filters-Attack Float 0.387750
Filters-Decay Float 0.405125
Filters-Sustain Float 0.000000
Filters-Release Float 0.414250
Filters-EG Depth Float 0.185625
Filters-Type Float 0.000000
Filters-Base Float 0.000000
Filters-Width Float 0.740125
Filters-Freq Float 0.599875
Filters-Res Float 0.598125
Filters-Keytrack Float 0.505000
Amp-Attack Float 0.313500
Amp-Decay Float 0.689750
Amp-Sustain Float 1.000000
Amp-Release Float 0.452125
Amp-Velocity Float 0.000000
Amp-Volume Float 0.726000
Amp-Pan Float 0.500000
Amp-Pan/Width Slct Float 0.000000
ToneGen-Harmonics Float 0.322414
ToneGen-HarmncLevel Float 0.222500
ToneGen-Ratio C Float 0.222222
ToneGen-Ratio A Float 0.063492
ToneGen-Ratio B Float 0.064264
ToneGen-Detune A/B2 Float 0.029310
ToneGen-Mix Float 0.531034
ToneGen-Feedcack Float 0.806250
ToneGen-Keytrack Float 0.656750
ToneGen-Algorithm Float 0.500000
ToneGen-TrigGate-A Float 0.000000
ToneGen-Attack-A Float 0.000000
ToneGen-Decay-A Float 0.800000
ToneGen-End-A Float 0.466667
ToneGen-Level-A Float 0.202125
ToneGen-Delay-A Float 0.000000
ToneGen-TrigGate-B Float 0.000000
ToneGen-Attack-B Float 0.266667
ToneGen-Decay-B Float 0.666667
ToneGen-End-B Float 0.466667
ToneGen-Level-B Float 0.236875
ToneGen-Delay-B Float 0.057750
ToneGen-C Offset Float 0.000000
ToneGen-A Offset Float 0.313750
ToneGen-B2 Offset Float 0.012500
ToneGen-B1 Offset Float 0.335000
Long preset name String
Posted: Wed Jan 12, 2022 8:29 pm
by k brown
Has anyone gotten this to work?
I can't get it to load, I think because it isn't formatted into tidy columns like presets are?
Posted: Wed Jan 12, 2022 8:31 pm
by deraudrl
Haven't had a chance to try it yet, but maybe replace spaces with tabs?
(At least in the actual parameter lines...)
Posted: Thu Jan 13, 2022 7:59 am
by billv
Thank you Mr Brown :D ...interesting synth... always a pleasure to go inside your schematics,and it's
always very educational..cheers :D
Posted: Thu Jan 13, 2022 11:41 am
by k brown
The most valuable tidbits inside are Spogg's work!
