Ensemble with fixed rate, delay, depth and mix.
Posted: Wed Sep 19, 2018 12:05 pm
by Halon
Here is another little unusual effect im currently working on.
Its a ensemble effect with fixed values (well almost. You can however use the appropriate buttons to select rate, depth and dry - wet levels, from slow to fast and minimum to maximum depth.) There is also a 'pre amp' section before the final output with fixed volume levels, where the last two add saturation. There is still some work to be done, but its fully functional. Hope you like it.
One last thing. It seems to lop more to the left side for some reason. Anyone could give me some points on how to fix that so the left and right are equal ?
Re: Ensemble with fixed rate, delay, depth and mix.
Posted: Wed Sep 19, 2018 10:37 pm
by nix
very neat-thank you.
looks nice too halon!
I'm sure you know, but I think it's lopping in the ensemble stage,
some stuff in there looks it could create the pan
Posted: Thu Sep 20, 2018 11:08 am
by Halon
Thank you Nick. :) I have to take a look.
Posted: Fri Sep 21, 2018 4:41 pm
by Spogg
Hi Halon
That's a very nice retro look you have there. It reminds me of something you'd find on a "Home Organ" many years ago!
I've made a few changes and added comments to the schematic.
I think it sounds really good now, but see if it's what you had in mind.
I'd like to put it on Flowstoners when you decide it's complete, but may I suggest you add an invisible preset manager so the DAW will remember settings with the song?
Posted: Tue Sep 25, 2018 1:25 pm
by Halon
Thank you Spogg, really appreciate it once again mate!
Yes i will add a preset manager indeed. I think I also forgot to add unique preset names for the knobs and buttons. Will work on it right away :)
Posted: Fri Sep 28, 2018 4:19 pm
by Halon
I just updated the first post with the final version. I already had a preset manager, but I made a couple of presets. I also added a information pop up.
