some good news and some bugs
Posted: Wed Nov 20, 2013 2:25 pm
It continues from here:
http://www.dsprobotics.com/support/view ... =160#p9038
While SM/FS can deal with relative filepaths directly, there is a problem with triggers. Or at least there was, when we worked on it with Trog, long time ago in SM age. Anyway, the solution to avoid "relative vs absolute" issues - was to provide fixed absolute path. Then triggers worked correctly. But how to do this if you prefer to move your file here and there?
Well - there is a primitive called "start folder". While when working with schematics - it shows "pass through" path you provide via input string, in exported files - it shows the path where exported file is physically located. Your input string is blocked. Below are few examples. Export it, move the file around the folders, run it, and see where the path leads.
And now the bad news. There is a primitive, that should show paths to your schematics. For some reason - sometimes it works, sometimes - not. When I started to put together things - it showed the path, but few FS restarts later - it no longer works on my machine. Moving the schematic somewhere else is not helping, modifying is not helping, modifying and reloading is not helping, so there seems to be some sort of bug.
If it would work, then you could use it to provide the absolute path to your schematic, and that path would follow your schematic. And it would not interfere with "start folder".
In the next post - I will wire for you some trigger work for loading files and acting when file isn't there.
