Can some one help me with AM mod? (SOLVED)
Posted: Mon Feb 17, 2014 6:04 pm
by ISounds
How do i make a simple AM mod. Or ring mod? Just a simple one. AM is more important.
Im after the one in 3xOsc.
Says Osc>3AM
For 3 oscilators.
OSC 3 Amplitude Modulation (OSC 3 > AM) - Switch on to use Oscillator 3 as an amplitude modulation of the other 2 oscillators.
AH sry i did find a old post fro mtrog showing this. Thnx anyway (SOLVED)
Re: Can some one help me with AM mod? (SOLVED)
Posted: Mon Feb 17, 2014 6:32 pm
by Jay
here is one!
AM mod.fsm
(76.31 KiB) Downloaded 1086 times
turn the red knob to hear it working! you can modulate it with whatever you want! modulation range is 0-1 ;)
Regards
Posted: Mon Feb 17, 2014 6:33 pm
by ISounds
Thnx alot jay i will check this. I wonder why do 3xosc dont have any knob for the AM? its just on off mode?
Realy strange :P
Posted: Mon Feb 17, 2014 6:46 pm
by Jay
No problem m8!
it is possibly being auto modulated by an adsr or lfo, or any other sources available on the synth! not sure! I take it you are talking about the little 3osc synth in FL studio?
not used it for a while, but i will take a look at it ;)
Posted: Mon Feb 17, 2014 6:51 pm
by Jay
Just had a look it does have a knob for the AM mod called pw! it randomizes the phase on all 3 osc's
the am mod on the 3osc is using the 3rd osc to modulate the output of osc 1&2
Posted: Mon Feb 17, 2014 7:14 pm
by ISounds
So how do i do this?
Its just to hook up one AM math and make so that am effect both osc 1 and 2?
Posted: Mon Feb 17, 2014 8:54 pm
by Jay
yeh m8 thats about it! and feed the output of osc3 into the mod input onthe am module!
now! the output signal of osc3 will need levered into the 0-1 range to work correctly i reckon!
i will have a play with it later and see if i can figure it out for ya :)
