Network UDP cant select address
Posted: Sat Feb 22, 2014 1:55 pm
by dinglebat
Im trying to make use of the network object for a UDP connection.
I have two wifi adapters (one for internet, the other one for an adhoc connection to the UDP stream)
However, Flowstone will only connect to the adapter being used for the internet. It refuses to connect to the adhoc connection.
In fact, FS just chooses which IP to connect to and even if I set this manually, it will still just choose itself.
Why is it that I cannot set the IP address of the network object?
Re: Network UDP cant select address
Posted: Sun Mar 02, 2014 4:46 pm
by zeroohmstudio@gmail.com
Dinglebat, do you have any success in this? I have the same issue, a wireless internet NIC and a local copper NIC. I want to choose copper based NIC and I cannot do it. Tried to modify NIC metric (manual), then used ForceBindIP.exe to bridge flowstone only to copper NIC ip. None working. Metric is not affecting network server NIC selection (wireles in my case) and ForceBindIP.exe fails server connect. Thanks.
