Hi-Rez MIDI [CC] values
Posted: Sat Apr 26, 2014 8:28 pm
by RJHollins
again with a new project idea ... but an important 1st question please ...
We know that standard MIDI uses control values of 0-127.
But there is also a protocol technique that can use a much finer resolution.
General question ... can we do this 'Hi-Rez' values with FS ??
Re: Hi-Rez MIDI [CC] values
Posted: Sun Apr 27, 2014 1:51 am
by billv
Finer resolution of 0-127 Midi .....
"Microtuning"....??
http://www.dsprobotics.com/support/view ... 225#p10266
Posted: Sun Apr 27, 2014 3:25 am
by Tronic
NRPN
14bit MSB LSB
Posted: Sun Apr 27, 2014 5:43 am
by RJHollins
ahhh ... OK Guys ....thanks to both.
Actually ... I think Tronic hit the with the
NRPN
14bit MSB LSB
I couldn't recall the exact name ... but the 14bit was the Hi-Rez version.
I think I remember seeing a module [from TROG ?] that had something about this ... will have to look in the tool shed ;) ..... YEP .... found something there 8-)
There was also a module that SOMEBODY put together called 'Audio to MIdi CC' ... can't remember where I found ... could have been on the SM forum .... anyway ...
The CRAZY idea.
I need to track an audio signal for it's MAX PEAK level, convert that MAX value into MIDI data, and then [via MIDI], send it to another VST plugin :shock: I know .... just plain crazy.
Actually, I was hoping that the 'passing' of data between to apps [plugins] would have been simpler, but it looks to knowing C++ and creating a special DLL file [something like that ... this was mentioned in another thread]. Well, at this stage, that's a bit beyond my ability :oops:
Thusly ... the idea to stream the data over MIDI, where I can establish 2-way communication. The idea is to be able to monitor audio levels and post that data at a point above the audio stream. The 'monitoring' plugin would also be a VCA that could be controlled [via MIDI] from this 'above' location in the FX chain. Ideally there would be several of these 'monitors' placed between other plugins in the chain, where the 'levels' can be monitored [and controlled] from a single location GUI.
Crazy ... :roll:
Anyway .... my hope is that with the Hi-Rez MIDI, I could have finer steps between values.
I do have a rather basic schematic that starts to demonstrate the idea, but I'm in the early stage of putting this design together.
May need to ask for GURU assist :o
:lol:
Again ... thank-you Gentlemen 8-)
