Page 1 of 3
FlowStone 3.0.6 PEBBLE
Posted: Mon Nov 03, 2014 11:04 pm
by tester
...is ready to download :mrgreen:
Re: FlowStone 3.0.6 PEBBLE
Posted: Mon Nov 03, 2014 11:28 pm
by Exo
I've done a quick Review :)
Posted: Tue Nov 04, 2014 12:06 am
by tester
But there is something wrong with this new indexer. From what I see - it picks "last" index in reversed order. Or am I missing something?
Posted: Tue Nov 04, 2014 12:57 am
by Attic
It seems to be down to wiring order . Notice it seems to always use the wire that was connected first as it traverses the schematic.
Posted: Tue Nov 04, 2014 1:31 am
by tester
Yes I see it, but this is still reversed order.
Posted: Tue Nov 04, 2014 12:43 pm
by Nubeat7
is there no way anymore to move into modules from the mainview?
there is this new feature to select the different views in the main window, before 3.05 it was possible to move into modules with a doubleclick, but now this isn't possible anymore, i mean its nice to select all viewlevels from the mainview but maybe an option in the rightclick menu to move over there would be really helpful, now i always need to dive down level for level and often in complex projects its diffcult to find what you are looking for...
Posted: Tue Nov 04, 2014 2:02 pm
by ISounds
ye i know i also tested this version. And get same problem with this as nubeat talking about. was a hell of work to do it this way. No option to go inside the synth.
Posted: Tue Nov 04, 2014 3:06 pm
by tester
Nubeat7 wrote:is there no way anymore to move into modules from the mainview?
This one is real PITA. Is there any other key shortcut to perform that "go to selected" operation? Actually what happens right now when you double click on gui parts in edit mode? They become inactive here.
Posted: Tue Nov 04, 2014 3:26 pm
by Nubeat7
the good thing is that you can place and resize all gui elements also when they are nested, that means you can select, place and resize all view levels from tha main view what you couldn't do before, but you cannot switch to the selected module what was done with the doubleclick before, all in all this is a good feature and makes gui organisation much easier, but sadly for the cost of directly jumping into the selected module.. or did i miss something?
Posted: Tue Nov 04, 2014 3:33 pm
by Exo
Nubeat7 wrote:the good thing is that you can place and resize all gui elements also when they are nested, that means you can select, place and resize all view levels from tha main view what you couldn't do before, but you cannot switch to the selected module what was done with the doubleclick before, all in all this is a good feature and makes gui organisation much easier, but sadly for the cost of directly jumping into the selected module.. or did i miss something?
It is much better now for arranging the GUI. But no it looks like the old 'feature' is gone, I bet Malc thought no one would miss that. I guess jumping to the module can still be useful.
