Filter Curve Display
Posted: Fri Jan 16, 2015 12:01 pm
by glitchcpt
Hey guys its me again :mrgreen:
I have another query, i think its still noob haha
anyway, I am trying to create a filter display curve, I managed to get this far, but it is acting rather like a peaking filter than a LPF in the display window.
Basically i need to make the float array append only the values below the "freq" input to -1, i think that should fix it, however I'm struggling with that,
Thanks in advance :D
Re: Filter Curve Display
Posted: Fri Jan 16, 2015 6:52 pm
by glitchcpt
UPDATE:
I managed to get the Band Pass, Band Reject and Peaking modes to display correctly :D
Still struggling with the Low Pass and High Pass
Posted: Fri Jan 16, 2015 10:39 pm
by KG_is_back
I think your main problem is, that you're doing it all wrong. Inside there is a "biquad frequency response" primitive, that builds the graph. You input the biquad coefficients and it builds the array for graph in given range.
Just before the prim you have a module called "Peaking EQ Biquad Coeffs" that calculates the biquad coefficients of a peaking filter from frequency, rez and gain. In order to make the graph to show also other filter types than peaking, you need to make more of these modules - for each filter type one and select between them.
This may prove complicated, since you want to show response of a 3x oversampled state-variable filter (which is somewhat equivalent to oversampled biquads LPF BPF HPF combination).
What I recommend is to use copy of the filter, connect it to impulse and Analyser prims. And use FFTgraph prim to extract the frequency response.
Posted: Sat Jan 17, 2015 6:22 am
by glitchcpt
Thanks KG, I guess its all a learning experience right? :lol:
I will try that idea, thanks man
Posted: Sat Jan 17, 2015 6:59 am
by glitchcpt
Editted
So far so good, thanks KG :)
I just need to touch up the graphic elements a bit, but its kind of exactly what i was looking for :twisted:
