Control a Property Value
Posted: Mon Mar 23, 2015 2:41 am
by Perfect Human Interface
I have a string prim which is set as a property, but it also takes an input to set the value of the string. What I'm trying to do is add a bool switch to control whether or not the string is set by the input.
I've tried a trigger switch and a selector, but neither works because, as I've found, whenever you open the properties panel the string "pulls" the value from the input.
Does anyone have any ideas how I might be able to switch off the input into a property value without the property "pulling" the value when the panel is opened?
Thanks in advance
Re: Control a Property Value
Posted: Mon Mar 23, 2015 5:49 am
by martinvicanek
You might need a trigger blocker or trigger switch. Trog's Trigger Tutorial is a great resource, search for it on the SM Forum if you havent't already done so.
Perfect Human Interface wrote:[...] as I've found, whenever you open the properties panel the string "pulls" the value from the input.
Strange, it does not behave that way here. :?
Posted: Mon Mar 23, 2015 7:58 am
martinvicanek wrote:Strange, it does not behave that way here. :?
You're right... I just tested it and it only does it in my current project. :?
