Generate Array?
Posted: Sat Nov 16, 2019 11:11 pm
by guyman
Ok last question for the day.
What's the best way to generate/calculate an array from scratch, in consistent relation to a function from last entry, or the index # ?
so just..
Designating # of x bins...
entering function (ie x=x+3... or x=index ..or x=index*2+3/4^179)
I'm going for pretty big arrays.....
Re: Generate Array?
Posted: Sun Nov 17, 2019 12:33 am
by RJHollins
Hi Guy ...
not sure exactly what your looking for ... but posted sometime back, TROG had put together a package of modules called 'TROGS TOOLZ'.
In the 'Auto Numbering folder is an AutoFunction Generator that can generate a variety of Arrays and functions.
not sure if this the latest ... but maybe can help:
Re: Generate Array?
Posted: Sun Nov 17, 2019 1:14 am
by tulamide
guyman wrote:What's the best way to generate/calculate an array from scratch, in consistent relation to a function from last entry, or the index # ?
If you know the size of the array beforehand, the best way is to use its built in method #new:
my_array = Array.new(20) { |index| index*2+3/4^179 }
## creates an array with 20 entries calculated from the code block {}
if you don't know the size beforehand you have to append to an existing array, for example:
my_array = []
index = 0
my_array << index*2+3/4^179
This will make you happy: https://ruby-doc.org/core-1.9.3/index.html
Re: Generate Array?
Posted: Sun Nov 17, 2019 3:55 pm
by martinvicanek
Some options for array creation are: :mrgreen:
Re: Generate Array?
Posted: Sun Nov 17, 2019 4:35 pm
by tulamide
martinvicanek wrote:...
It does, Martin, it does. But for a good reason. It's not "the best" way as asked, it's the worst way, because it's not the Ruby way. A for loop is one of the worst methods, especially when doing large arrays, as the op said.
But the other methods impress me! I would never had thought about using ASM, that's amazing!
Re: Generate Array?
Posted: Fri Nov 22, 2019 7:58 pm
by wlangfor@uoguelph.ca
i like to build an array, as long as you're sure the index number is accurate there really is no drawback unlike javascript or php.
