shell execute +batch file
Posted: Tue Aug 04, 2015 12:58 am
Hi!
I would like to run a batch file with the shell execute in the cmd. i am not pro in batch file. My problem, when i copy the batch into a text string and i run the exported exe, the exe file chrashes. Can the shell execute to run a complex command lines with cmd or it's work only per line?
My next test. I tryed to run the example.cmd batch file directly with the shell execute, but the cmd window not opened.
So what can i do?
Thank you!
So what can i do?
Thank you!
