Access to other Tracks in the DAW
Posted: Tue Sep 01, 2015 2:28 pm
How is it possible to get access to other tracks in the DAW. I'd like to build vst plugins that can stream other track e.g. as a sidechain.
DSP Robotics and FlowStone Graphical Programming Software Support and Forums
https://dsprobotics.com/support/
Thank you tulamide. I tried it and it worked so far. I can choose many sidechains in my pluginwindow, all routed on the sidechainstream in the plugin, poorly they are not separated.tulamide wrote:...For example, if you create 4 mono inputs, you can use them as 2 stereo pairs, for example for the main stream and a sidechain. ...
