Variable-length loops. i.e. loop(n) {...}
Posted: Fri May 01, 2020 2:56 pm
I think I'm right in saying that DSP in FS3 doesn't allow variable-length loops. FS4 does, but as far as I can see there's nothing to prevent doing them in FS3 when you're in assembler. (If I'm wrong I'll head on back to Slack ...
So, I'm inputting an int 'loopLength' to define the loop. FS4 typically gives you this assem for a variable-length loop :
But today I accidentally hit on this as a nice simplification, using cvtss2si to directly get loopLength into eax, instead of all the fld/fistp stuff .. which I barely understand anyway! (Much of my so-called assembler coding has its origins in the accidental
Appears to work OK, but seems too easy. Can one of the code team tell me if it's generally OK to do this? I foresee pitfalls ...
H
streamin loopLength;
float _temp_;
// Start of Loop {
movaps xmm0,loopLength;
movaps _temp_,xmm0;
fld _temp_[0]; fistp _temp_[0]; mov eax,_temp_[0];
loop1:
push eax;
// my code
pop eax;
dec eax;
jg loop1;
// } End of LoopCode: Select all
// Start of Loop {
cvtss2si eax,loopLength;
loop1:
push eax;
// my code
pop eax;
dec eax;
jg loop1;
// } End of LoopH
