Drumzatron Deluxe SFZ Drum Machine/Sequencer
Posted: Sun Jun 07, 2020 11:02 am
by pwesynthmaker
Updated: 06/26/26
Drumzatron Deluxe
Soundfont SFZ
Drum Machine/Graph Grids Sequencer
w/Improved BPM Sync Echo
Drumzatron Deluxe Download Link:
https://www.inventfx.com/_ifxfstone/drmzatrondlx.zip
Drumkit Soundfont SFZs Download Link:
https://www.inventfx.com/_ifxfstone/pwedrmsfzs.zip
View Large Image:
https://www.inventfx.com/_ifxfstone/drmzatrondlx_lg.jpg
INSTALLING THE VSTI PLUGIN
There are 3 different sizes of VSTi Plugins: Large, Medium and Small.
Each size has a complement of 4 x64 (2 ea. 32bit and 64bit) VSTi
and 1 x86 (32bit) VSTi.
One of each different size of ONLY one type is allowable.
CAUTION! DOT NOT INSTALL TWO SIZES OF THE SAME TYPE.
EXAMPLE: LG.*.VST3 & MD.*.VST3 IS NOT ACCEPTABLE!
IT IS ACCEPTABLE TO USE ONE OF EACH SIZE OF ANY OF THE 4 TYPES:
32BIT
drmzatrondlx.dll (x86) [v3.0.6x86_32bit Folder]
or drmzatrondlx.dll (x64)
drmzatrondlx.vst3
AND 64BIT
drmzatrondlx (64).dll
drmzatrondlx (64).vst3
USING THE STANDALONE EXECUTABLE
After downloading the drmzatrondlx.zip file and extracting files from same
open the drmzatrondlx.exe folder to utilize the standalone executable ...
Use the Mouse to 'Right Button Click' on the program and select a larger size
for easier viewing and operation of the controls.
For optimum size select 'Full Screen' and then 'Fit Screen' to view properly.
GRAPH GRID ORIENTATION
The Drumkit Graph Grid has the 'midimap' listing for each percussion instrument on the left side.
NOTE:
Drumkit Percussion Instruments are identified by their respective midimap
(*number) = piano keyboard musical note.
This tuning is based upon the GM (general midimap) reference.
Starting from the bottom and progressing upwards the Drumkit Graph Grid is 'tuned' from
(*27) = Eb0 to (*88) = E5
The description for each individual percussion instrument on the left is based upon this.
DRUMKIT MUSICAL NOTE TUNING
Different drumkit sfzs can vary in tuning for their individual instruments.
This will show non-matching instrument name/tuning on the graph.
Refer to the midimap reference for each different drumkit sfz for assistance.
DRUMKIT SFZ MIDDLE C CAN VARY FROM C3 TO C5 OR EVEN AN ARBITRARY PIANO KEYBOARD NOTE.
USE THE SAMPLER OCT/SEMI (OCTAVE/SEMIITONE) 'DETUNER' TO COMPENSATE.
LOADING A SOUNDFONT SFZ FILE
Drumzatron Deluxe utilizes a Soundfont SFZ file for the graph grid sampler
NOTE: It is necessary to load a drumkit SFZ soundfont into the sampler (lower left corner) at startup.
If a Soundfont SFZ file is not already loaded ...
from one of the drumkit soundfont folders provided in the additional download ...
The Drumkit MIDI Map on the left side of the sequencer is based on the General Midi Standard Drumkit only.
Drumkit soundfont sfzs are in the pwedrmsfzs subfolder.
Stereo Drumkit soundfonts sfzs are in the pwedrmstsfzs subfolder.
INCLUDED EXAMPLE SOUNDFONT SFZ FILE TO LOAD ---
Drumkit Graph Grid Sequencer Soundfont:
(4.) kngmelecst2.sfz
The Drumkit SFZ files provide three different types of playback duration.
Filename: *1.sfz --- 'no_loop' version (matches note length).
Filename: *2.sfz --- 'one_shot' version (plays sustained full length for a more natural sound).
Filename: *3.sfz --- 'continuous_loop' version (loops continuously).
Re: Drumzatron 4 SFZ Drum Machine/Sequencer
Posted: Sun Jun 07, 2020 4:09 pm
by deraudrl
Download link for the zip file 404's...the other link is good.
Posted: Sun Jun 07, 2020 8:59 pm
by pshannon
@pwesynthmaker I got the same thing 404. Thanks for teasing us :lol: with the drum machine v4. You have posted some good stuff.
I figured it out, here is the link: https://www.invntefx.com/ssl/_invntefxf ... atron4.zip
