Quilcom QX7 Mods
Posted: Fri Jan 08, 2021 5:39 am
by newdsp
Here are a few mods for QX7. Version 1.13 has stereo random panning on the delay effect (sounds way better when the feedback is high) and v1.14 changes the colors when the RESET button is pressed. So... Don't press it. Stay away from it. Don't touch it. Version 1.15 has the pan speed set by the delay time.
Re: Quilcom QX7 Mods
Posted: Fri Jan 08, 2021 8:14 am
by newdsp
I had to completely change the delay effect to add the 3/16 note.
Posted: Fri Jan 08, 2021 8:02 pm
by newdsp
Here is another version with the UI re-arranged to be more consistent but it's still not finished. I also had to re-wire the delay panner to turn on only when the delay is turned on. Maybe it should be a separate module. I also disconnected the master volume from the preset manager so that when you change presets the volume remains the same.
Posted: Sat Jan 09, 2021 4:54 am
by newdsp
Here is the latest modified version of QX7. Link is in the video description but also here.
https://youtu.be/rJEbWMWYG4A
https://drive.google.com/file/d/1NTYqlA ... sp=sharing
