Pulse Width Modulation (PWM)
A wide range of example files that you can load up in FlowStone
Postby admin » Fri Jul 16, 2010 5:50 pm
In this example a PWM signal is created using the soundcard output, and can be controlled in Flowstone to vary the pulse width for motor or servo control applications.
If you have several motors to control I would recommend you look at the Phidgets motor controller, this does the PWM on board so you only have to tell it a required motor speed.
PWM.fsm
(59.04 KiB) Downloaded 2992 times
admin
Site Admin
Return to FlowStone Examples
cron
