Bug light meter vu
Bug light meter vu
Postby rustyou » Sat Mar 01, 2014 4:01 pm
Hello,
I have a bug or probleme in the meter vu (look project)
The light does not respond when i clik on the switch (on, off light of screen on, off)
Why ?
bug light vu meter.fsm
(362.83 KiB) Downloaded 881 times
rustyou
Re: Bug light meter vu
Postby Nubeat7 » Sat Mar 01, 2014 4:41 pm
you need to insert and connect redraw primitives
Postby rustyou » Sat Mar 01, 2014 5:18 pm
Hi !
Exemple of this solution please ?
Thanks you,
rustyou
Postby Nubeat7 » Sat Mar 01, 2014 5:38 pm
i'm sure you can do it! just insert a redraw primitive inside the modules where you select between the 2 images and trigger it with the switch signal ;)
Postby rustyou » Sat Mar 01, 2014 5:52 pm
Look !!
I'm happy !
Thanks you so much for you help :)
(362.86 KiB) Downloaded 907 times
rustyou
