help with sfz player!!!
Postby apoc123 » Thu Jul 17, 2014 9:03 pm
can anyone explain why i can not load in an sfz into the sfz player, it will load but no sound and i have it hooked up right i believe it looks like it load the sfz but does not load the samples or paremeters
apoc123
Re: help with sfz player!!!
Postby kortezzzz » Fri Jul 18, 2014 6:45 am
Hi!
Please, share your full schematic file. Upload it here and you'll get the needed help.
kortezzzz
Postby CoreStylerz » Fri Jul 18, 2014 10:26 am
Make sure your SFZ are compatible some didn't load correctly.
PM me if you are interested.
CoreStylerz
Postby apoc123 » Sat Jul 19, 2014 11:03 pm
HERE IS A LINK TO THE SCHEMATIC AND AN SFZ TO LOAD INTO IT.... PLEASE HELP GUYS.....maybe im not doin something right....
SCHEMATIC
http://www.uploadmb.com/dw.php?id=1405807161
SFZ
http://www.uploadmb.com/dw.php?id=1405807356
apoc123
Postby kortezzzz » Sun Jul 20, 2014 5:56 am
Hi.
Here is the schematic+fixed sfz file. Work fine on my machine.
Take a look inside the sfz (open it using notepad) and see what has changed comparing the first one.
Generally, my best suggestion is to leave inside the sfz only the most basic properties and make the
advanced tweaking inside FS. I'v also added a ADSR to avoid stuck notes and fatal release problems;
very important when working with samples.
Try it and report.
http://www.uploadmb.com/dw.php?id=1405831646
kortezzzz
Postby apoc123 » Mon Jul 21, 2014 2:35 pm
thanks kortez....!!!!
apoc123
Postby apoc123 » Mon Jul 21, 2014 4:23 pm
Hey Kortez...... I got it working man thanks! I have one problem now, my adsr is acting weird, I cant press a note and have it sustain and decay a little after I release the midi key, I tried rewiring in different places with no luck...... the adsr works but it only alters the sample if I hold it down....as soon as I release the midi keyboard note, it abruptly stops no matter if I have the decay sustain and release all the way up.........help brother and thanks so much!
apoc123
Postby kortezzzz » Mon Jul 21, 2014 9:30 pm
Lets try again. What I'v done is deleting the multisample module's inner adsr that causes sometimes weird behavior and also eating to much CPU, and by that, gave the full control to the added adsr module. the file is attached.
By the way, people, we must have a "hard to trace" multisample format inside FS, instead of SFZ format, that supports closed and un-convertable soundbank (like SF2, but unique...) . There is no way we can protect our samples when releasing a sampler, which means there is no point to built and release one. There are lot of formats that FS can adopt. Just looked today into "awave studio" and saw; THIS IS MUST BE DONE.
( uploadMB.com ) SFZ PROBLEM_fixed2.fsm
(68.38 KiB) Downloaded 954 times
kortezzzz
Postby apoc123 » Tue Jul 22, 2014 1:59 am
THANKYOU so much kortez and I agree we should come up with a non-stealable sample system, I like the way nexus has there fxp files...... we will figure something! thanks again for the help
apoc123
