Printing in a kind'o'way
If i have an image file i can print this from within fs with;
rundll32 C:\WINDOWS\system32\shimgvw.dll,ImageView_PrintTo "c:\myfile.bmp" "Brother DCP-165C Printer"
The thing i am looking for is capturing a part of the fs window, saving it and then pipe of to shimgvw.dll
This is were i am stuck, as the final gui doesn't have separate wHandle's , so my thinking of current is to take the values of a module and launch in a separate window where i can pre format the data & then print.
All ideas appreciated
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
Re: Printing in a kind'o'way
My idea is to grab the screen with simulate the key press of keyboard Print, so save the clipboard data to file, open it in FS, manipulate and send it to Printer.
- Tronic
Problem with send keys, how do you interpret when a user uses the keyboard & how do you edit the image only to include the area you want.
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
using only commnd line thing, or WinAPI you can not do what you want,
with the WinAPI but you may do so:
check the focus of the current window
simulate a keypress button Print
save the image that is now on the clipboard
to have a control over the size and position you should opt for a solution in DLL
- Tronic
I've already started with gdi , but thanks tho!
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
With win32api i am trying to put these pieces together slooooowly
Win32API.new("user32", "GetWindowDC", "L", "L")
Win32API.new("gdi32", "CreateCompatibleDC", "L", "L")
Win32API.new("gdi32","CreateCompatibleBitmap", ["L", "I", "I"], "L")
Win32API.new("gdi32", "SelectObject", ["L", "L"], "L")
Win32API.new("gdi32", "BitBlt", "L", "I", "I", "I", "I", "L", "I", "I", "L", "B")
#Pipe from mem to printer
#ReleaseDC
#DeleteDC
#DeleteObject
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
JB_AU wrote:With win32api i am trying to put these pieces together slooooowly
#ReleaseDC
#DeleteDC
#DeleteObject
One question: Where do you grab the constants' values from? I was interested in doing some win32api accessing, too, when trying to provide a solution for menus and listboxes, but the neccesssary constants' values are not on msdn, just their names. Are you using the header files? Where did you download them? Questions over questions...
https://www.google.co.jp/?hl=en&gws_rd=ssl
Which gives more information on ruby & win32api than "EnGoogle" itself
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
Strolling for more information i came across these goodies
And this i like too;
I'm salivating
require 'Win32API'
module GDIP
CLSID_BMP = '557CF400-1A04-11D3-9A73-0000F81EF32E'
CLSID_JPEG = '557CF401-1A04-11D3-9A73-0000F81EF32E'
CLSID_GIF = '557CF402-1A04-11D3-9A73-0000F81EF32E'
CLSID_TIFF = '557CF405-1A04-11D3-9A73-0000F81EF32E'
CLSID_PNG = '557CF406-1A04-11D3-9A73-0000F81EF32E'
CLSID_QUALITY = '1D5BE4B5-FA4A-452D-9CDD-5DB35105E7EB'
CP_ACP = 0x0000
CP_UTF8 = 0xFDE9
MultiByteToWideChar = Win32API.new('kernel32', 'MultiByteToWideChar', 'iipipi', 'i')
FindWindow = Win32API.new('user32', 'FindWindow', 'pp', 'l')
GetDC = Win32API.new('user32', 'GetDC', 'i', 'i')
ReleaseDC = Win32API.new('user32', 'ReleaseDC', 'ii', 'i')
BitBlt = Win32API.new('gdi32', 'BitBlt', 'iiiiiiiii', 'i')
CreateCompatibleDC = Win32API.new('gdi32', 'CreateCompatibleDC', 'i', 'i')
CreateCompatibleBitmap = Win32API.new('gdi32', 'CreateCompatibleBitmap', 'iii', 'i')
SelectObject = Win32API.new('gdi32', 'SelectObject', 'ii', 'i')
DeleteDC = Win32API.new('gdi32', 'DeleteDC', 'i', 'i')
DeleteObject = Win32API.new('gdi32', 'DeleteObject', 'i', 'i')
GdiplusStartup = Win32API.new('gdiplus', 'GdiplusStartup', 'ppi', 'i')
GdipCreateBitmapFromScan0 = Win32API.new('gdiplus', 'GdipCreateBitmapFromScan0', 'iiiipp', 'i')
GdipCreateBitmapFromHBITMAP = Win32API.new('gdiplus', 'GdipCreateBitmapFromHBITMAP', 'iip', 'i')
GdipBitmapConvertFormat = Win32API.new('gdiplus', 'GdipBitmapConvertFormat', 'piiipi', 'i') rescue nil
GdipSaveImageToFile = Win32API.new('gdiplus', 'GdipSaveImageToFile', 'pppp', 'i')
GdipDisposeImage = Win32API.new('gdiplus', 'GdipDisposeImage', 'p', 'i')
GdiplusShutdown = Win32API.new('gdiplus', 'GdiplusShutdown', 'p', 'v')
UuidFromString = Win32API.new('rpcrt4', 'UuidFromString', 'pp', 'i')
GdipBitmapLockBits = Win32API.new('gdiplus', 'GdipBitmapLockBits', 'ppiip', 'i')
GdipBitmapUnlockBits = Win32API.new('gdiplus', 'GdipBitmapUnlockBits', 'pp', 'i')
RtlMoveMemory = Win32API.new('kernel32', 'RtlMoveMemory', 'ppi', 'v')
PF_RGB = 0x00021808
PF_ARGB = 0x0026200A
WINDOW_TITLE = load_data("Data/System.rvdata2").window_title.encode('SHIFT_JIS')
WINDOW_HANDLE = FindWindow.call("RGSS Player", WINDOW_TITLE)
module_function
def MultiByteToWideChar(str)
buffer = [""].pack('Z256')
MultiByteToWideChar.call(CP_UTF8, 0, str, -1, buffer, buffer.size)
return buffer
def GetDC(hwnd)
return GetDC.call(WINDOW_HANDLE)
def ReleaseDC(hwnd, hdc)
ReleaseDC.call(hwnd, hdc)
def CopyDC(dest, src, width, height)
BitBlt.call(dest, 0, 0, width, height, src, 0, 0, 0xCC0020)
def CreateCompatibleDC(hdc)
return CreateCompatibleDC.call(hdc)
def CreateCompatibleBitmap(hdc, width, height)
return CreateCompatibleBitmap.call(hdc, width, height)
def SelectObject(hdc, obj)
return SelectObject.call(hdc, obj) != 0
def DeleteDC(hdc)
DeleteObject.call(hdc)
def DeleteObject(obj)
DeleteObject.call(obj)
def GdiplusStartup(token)
ret = GdiplusStartup.call(token, [1, 0, 0, 0].pack("i4"), 0) == 0
unless ret
msgbox "GDI+ failed in the initialization."
return ret
def GdipCreateImageFromBitmap(bitmap)
gpbmp = [0].pack("i")
if GdipCreateBitmapFromScan0.call(
bitmap.width, bitmap.height, 0, PF_ARGB, 0, gpbmp) == 0
image = gpbmp.unpack("i")[0]
r = [0, 0, bitmap.width, bitmap.height].pack("i4")
bd = [0, 0, 0, 0, 0, 0].pack("i6")
GdipBitmapLockBits.call(image, r, 3, PF_ARGB, bd)
GdipBitmapUnlockBits.call(image, bd)
bd = bd.unpack("i*")
data = Array.new(bitmap.width * bitmap.height * 4, 0).pack("C*")
RtlMoveMemory.call(data, bitmap.data, data.size)
data = data.unpack("C*")
data = Array.new(bitmap.height) do |i|
data[data.size - bitmap.width * 4 * (i + 1), bitmap.width * 4]
end.flatten!.pack("C*")
RtlMoveMemory.call(bd[4], data, bitmap.width * bitmap.height * 4)
return image
else
return nil
def GdipCreateImageFromHBITMAP(hbm)
if GdipCreateBitmapFromHBITMAP.call(hbm, 0, gpbmp) == 0
return gpbmp.unpack("i")[0]
else
return nil
def GdipSaveImageToFile(image, filename, clsid)
ret = GdipSaveImageToFile.call(image, filename, UuidFromString(clsid), 0)
msgbox "failed to save." if ret != 0
def GdipImageConvertPixelFormat(image, pixel_format)
return unless GdipBitmapConvertFormat
GdipBitmapConvertFormat.call(image, pixel_format, 0, 0, 0, 0)
def GdipDisposeImage(image)
GdipDisposeImage.call(image)
def GdiplusShutdown(token)
GdiplusShutdown.call(token)
def UuidFromString(clsid)
uuid = [0].pack("i")
UuidFromString.call(clsid, uuid)
return uuid
class Bitmap
RtlMoveMemory_pi = Win32API.new('kernel32', 'RtlMoveMemory', 'pii', 'i')
RtlMoveMemory_ip = Win32API.new('kernel32', 'RtlMoveMemory', 'ipi', 'i')
def info
dib = [40, self.width, self.height, 1, 32, 0, 0, 0, 0, 0, 0].pack("i3s2i6")
return [dib].pack("P").unpack("i")[0]
def data
buffer = [0].pack('L')
RtlMoveMemory_pi.call(buffer, object_id * 2 + 16, 4)
RtlMoveMemory_pi.call(buffer, buffer.unpack("L")[0] + 8, 4)
RtlMoveMemory_pi.call(buffer, buffer.unpack("L")[0] + 16, 4)
return buffer.unpack("L")[0]
def save(fn, type, back = nil)
bitmap = Bitmap.new(self.width, self.height)
case back
when Color; bitmap.fill_rect(self.rect, back)
when Array; bitmap.fill_rect(self.rect, Color.new(*back))
when /^white$/i; bitmap.fill_rect(self.rect, Color.new(255, 255, 255))
bitmap.blt(0, 0, self, self.rect)
case type
when /^BMP$/i; clsid, ext = GDIP::CLSID_BMP, ".bmp"
when /^PNG$/i; clsid, ext = GDIP::CLSID_PNG, ".png"
when /^JPE?G$/i; clsid, ext = GDIP::CLSID_JPEG, ".jpg"
when /^GIF$/i; clsid, ext = GDIP::CLSID_GIF, ".gif"
else; raise ""
fn += ext if File.extname(fn).empty?
filename = GDIP::MultiByteToWideChar(fn)
token = [0].pack("i")
if GDIP::GdiplusStartup(token)
image = GDIP::GdipCreateImageFromBitmap(bitmap)
if image
GDIP::GdipSaveImageToFile(image, filename, clsid)
GDIP::GdipDisposeImage(image)
GDIP::GdiplusShutdown(token)
bitmap.dispose
def save_png(filename, alpha = false)
save(filename, :PNG, alpha ? nil : :white)
module Graphics
def self.save_screen(fn, type)
case type
else; raise ""
wnddc = GDIP::GetDC(GDIP::WINDOW_HANDLE)
memdc = GDIP::CreateCompatibleDC(wnddc)
hbm = GDIP::CreateCompatibleBitmap(wnddc, Graphics.width, Graphics.height)
if GDIP::SelectObject(memdc, hbm)
GDIP::CopyDC(memdc, wnddc, Graphics.width, Graphics.height)
image = GDIP::GdipCreateImageFromHBITMAP(hbm)
GDIP::GdipImageConvertPixelFormat(image, GDIP::PF_ARGB)
if image
GDIP::ReleaseDC(GDIP::WINDOW_HANDLE, wnddc)
GDIP::DeleteDC(memdc)
GDIP::DeleteObject(hbm)
require 'Win32API'
OpenPrinter = Win32API.new('winspool.drv','OpenPrinter', ['P', 'P', 'P'], 'L')
StartDocPrinter = Win32API.new('winspool.drv','StartDocPrinter', ['L', 'L', 'P'], 'L')
EndDocPrinter = Win32API.new('winspool.drv','EndDocPrinter', ['L'], 'L')
WritePrinter = Win32API.new('winspool.drv','WritePrinter', ['L', 'P', 'L', 'P'], 'L')
ClosePrinter = Win32API.new('winspool.drv','ClosePrinter', ['L'], 'L')
GetLastError = Win32API.new('kernel32','GetLastError', [], 'L')
def open_printer(nm, dev=nil)
hdl = [0].pack("I")
r = OpenPrinter.call(nm, hdl, nil)
hdl = hdl.unpack("I")[0]
[r, hdl]
def start_doc_printer(hdl)
StartDocPrinter.call(hdl, 1, "\0"*4*3)
def write_printer(hdl, data)
sz = [0].pack("I")
rslt = WritePrinter.call(hdl, data, data.size, sz)
[rslt, sz.unpack("I")[0]]
def end_doc_printer(hdl) EndDocPrinter.call(hdl) end
def close_printer(hdl) ClosePrinter.call(hdl) end
if __FILE__ == $0
if ARGV.size <= 1
print "Usage: #{$0} spoolfile printer\n"
exit
prn = ARGV[1].dup
rslt, hdl = open_printer(prn)
print "OpenPrinter(#{prn}) --> #{rslt}, hdl:#{hdl}\n"
rslt = start_doc_printer(hdl)
print "startDocPrinter --> jobnum: #{rslt}\n"
spldata = ""
File.open(ARGV[0], "rb") {|fp| spldata = fp.read}
rslt, sz = write_printer(hdl, spldata)
print "WritePrinter --> #{rslt}, size:#{sz}, err:#{GetLastError.call}\n"
rslt = end_doc_printer(hdl)
print "endDocPrinter --> #{rslt}\n"
rslt = close_printer(hdl)
print "closePrinter --> #{rslt}\n"
I'm salivating
Albert Einstein
Albert Einstein
JB_AU - Posts: 171
JB_AU wrote:Strolling for more information i came across these goodies
require 'Win32API'
module GDIP
CP_ACP = 0x0000
CP_UTF8 = 0xFDE9
PF_RGB = 0x00021808
module_function
return buffer
def GetDC(hwnd)
def DeleteDC(hdc)
unless ret
return ret
return image
else
return nil
else
return nil
return uuid
class Bitmap
def info
def data
case back
case type
else; raise ""
if image
bitmap.dispose
module Graphics
case type
else; raise ""
if image
require 'Win32API'
hdl = [0].pack("I")
[r, hdl]
sz = [0].pack("I")
if __FILE__ == $0
if ARGV.size <= 1
exit
prn = ARGV[1].dup
spldata = ""
I'm salivating
Very cool JB_AU
I might have to look into this more myself
- Exo
Users browsing this forum: No registered users and 70 guests
