P.b. doesn't work after passing midi through midi event.
Really strange... Just found out that if passing midi signal through midi split-midi event combination, the pitch band wheel stops responding. Tried to split the keyboard into 2 ranges by using the green "split-event" and it works, but can't give up for the pitch-band
Maybe there is any nice Ruby solution for keyboard spliting that would keep the pitch-band a live, unlike the green one?
kortezzzz - Posts: 763
Re: P.b. doesn't work after passing midi through midi event.
The problem might be, that your filter only passes note events through(CC events are filtered out). Use the original midi input to extract bitch bend and midiCC data.
there is a special midi pitchbend primitive for pitchbend
Nubeat7 - Posts: 1347
Yeh, figured it out. Thanks for the spot. It works
Users browsing this forum: No registered users and 59 guests
