Is there a TCP/IP stack
Is there a TCP/IP stack/software module/component in the works ?
Many of us need to monitor/control things over the web.
Or did I miss this ... in the Doc's ?
Tks,
Tks,
- vostryc
Re: Is there a TCP/IP stack
There is a TCP IP module in FS Pro.
The data coming out of the TCP module is Strings, so if you need to buffer the data you can use the String Stack component.
This works really well on a LAN or over the web!
- Embedded
Hey where is this module located?
ive got FS pro & I cant seem to find it??
******WAIT*****
Found it uder 'Network Client' module
******WAIT*****
- Drnkhobo
