Ruby Help
Ruby Help
Postby DaveyBoy » Tue Mar 28, 2017 9:18 pm
Hi all
Needing some help if one of you Ruby experts could assist.
I have a hash that I need to change:
I've been Googling this for two days now to no avail, so I thought I'd ask here :D
In order to get the result I want I have to call a definition and change it, surely it must be possible to get the result in one definition... its self explanatory if you care to have a look:
@my_hash = { 0 =>"Piano", 1 =>"Guitar", 5 =>"Flute" }
def my_1st_attempt
   (0..6).map {|n| a = @my_hash.fetch(n,"- - -");Hash[n,a]}
def result_that_i_want
   my_1st_attempt.reduce Hash.new, :merge
watch "my_1st_attempt", my_1st_attempt
watch "result_that_i_want", result_that_i_want
Hope someone can help :cry:
PS sorry for the blurred pic . . . Had to resize it
DaveyBoy
Re: Ruby Help
Postby KG_is_back » Wed Mar 29, 2017 1:18 am
basically what you want to do is to add element to a hash if it doesn't already exist. There are several ways to do this:
#version 1
(0..6).each{|n|
@my_hash[n] = @my_hash[n] || "- - -" #if fetched element is nil, puts "- - -" in its place
#version 2
(0..6).each{|n|
if not(@my_hash.has_key?(n)) #if given key is not present in hash
@my_hash[n] = "- - -" #put new element in that place
#version 3
#this version adds default element to the hash, which is returned by default unless specific value is specified
#this is different from your expected output, but it might be what you actually want.
@my_hash.default="- - -"
@my_hash[1] #returns "Guitar"
@my_hash[2] #returns "- - -" because key 2 is not present in the hash
KG_is_back
Re: Ruby Help
Postby DaveyBoy » Wed Mar 29, 2017 8:43 pm
Hi KG
Thanks for the quick reply
Yep... that did the trick. I had to play about with it to get it to do what I want it to do but I got there in the end thanks to your help :D
I am auto-generating blank lines in a list and this does the job perfectly.
Thanks again KG
DaveyBoy
