SM prims can be used can't be added to FS toolbox
Here is a strange situation. There are primitives from synthmaker, that can be used in flowstone, but you can't add them to the toolbox. Are there more like these?
BTW, can somebody make a schematic with modules, that are in SM, but were not added to FS?
prims.fsm- (217 Bytes) Downloaded 1022 times
Re: SM prims can be used can't be added to FS toolbox
You can't add primitives to the toolbox (regardless where they are from). If you want to add them, put them into a module and add the module to the toolbox
MyCo - Posts: 718
I see, my mistake.
Are there more prims missing in FS?
Over at the SM forum, it was posted, ...
Does this work manually moving the .hom files ?
by malc on Thu Sep 20, 2012 3:37 pm
3. There won't be any automatic migration. You'll need to manually move the .hom files or put your modules in a schematic, load them into FS and drag them to the toolbox. It *shouldn't* be too much work.
tester wrote:I see, my mistake.
I don't know... Since I work with it, the only primitive that I've missed was the FFT-Window that you mentioned.
RJHollins wrote:Does this work manually moving the .hom files ?
Yes it works, but don't know if they are getting the right Tags in FS. But when I need to port something from SM to FS, I just open a SM Schematic and copy the parts that I need.
MyCo - Posts: 718
