uChameleon 2
uChameleon 2
Postby DSP » Sun May 15, 2011 12:03 am
Just tested FlowStone with the uChameleon 2 from Starting Point Systems. I used the little test program posted by 'Embedded' which worked fine (although the LED logic was the other way).
Another thing on my test PC which is XP, it doesn't like COM ports > 8, this is the case with all Com port devices not just this one. So I had to change the default com port from 11 to 8 in the windows driver, the other settings were fine 9600,n,8,1.
Now I have it working, I'll add some more functionality in this thread.
Here's the test project (with the led fixed):
µChameleon Test V1-00.fsm
uChameleon 2
(20.96 KiB) Downloaded 1443 times
DSP
Re: uChameleon 2
Postby DSP » Mon May 16, 2011 5:08 pm
Done and uploaded: http://www.dsprobotics.com/support/viewtopic.php?f=11&t=235
Works great with FlowStone!
DSP
